HP iPAQ Voice Messenger and HP iPAQ Data Messenger - Troubleshooting when the Unit Battery Drains Rapidly
Symptoms
The HP iPAQ Data Messenger and the HP iPAQ Voice Messenger devices battery may sometimes drain rapidly. This may occur due to various factors such as old ROM version, third-party applications running on the device, and the device usage.
Resolution
Perform the following troubleshooting steps when the device battery drains rapidly.
Step 1: Updating the device with latest ROM update
Make sure the latest ROM update is installed on the device. You can check the latest ROM updates for HP iPAQ Data Messenger and HP iPAQ Voice Messenger devices at www.hp.com/support.
Step 2: Uninstalling third-party applications
Uninstall any third-party applications that take up more battery power. To uninstall third-party applications on the device, follow these steps:
You can only remove programs that have been installed after purchase. You cannot remove the iPAQ default programs.
On HP iPAQ Voice Messenger:
  1. Press Start > Settings > Remove Programs.
    Figure : Removing applications from HP iPAQ Voice Messenger
  2. Select the program to remove.
  3. Press Menu > Remove.
On HP iPAQ Data Messenger:
  1. Tap Start > Settings > System > Remove Programs.
    Figure : Remove applications from HP iPAQ Data Messenger
  2. Select the program to remove and tap Remove.
Use the chart below to check if your device usage confirms to the expected results.
Scenario
Expected time before recharging the battery
2G signal
2G signal
3G signal
3G signal
Call/Receive less than 5 calls a day with limited or no data service
20 - 24 hrs
16 - 20 hrs
15 - 18 hrs
12 - 15 hrs
Call/Receive 5 -10 calls in a day with no data service
12 - 15 hrs
10 - 12 hrs
9 - 11 hrs
7 - 8 hrs
Call/Receive 5-10 calls a day with average usage of data like e-mails (exchange server)
10 - 12 hrs
8 - 10 hrs
7 - 9 hrs
5 - 6 hrs
Call/Receive more than 10 calls a day with no data service/usage
6 -12 hrs
5 - 10 hrs
5 - 9 hrs
4 - 7 hrs
Call/Receive more than 10 calls a day and uses data service like e-mail and browsing
4 -6 hrs
3 - 5 hrs
3 - 5 hrs
3 - 4 hrs
Mainly uses device for streaming media 100% of the time (worst case scenario)
3 - 4 hrs
2 - 3 hrs
3 - 4 hrs
2 - 3 hrs
If the battery operates under the above parameters go to step 3 else go to step 4.
Step 3: Improving the battery life
To find more information on improving the battery life, check the following topics/manuals on www.hp.com/support.
  • HP iPAQ Voice Messenger - Battery Saving Tips
  • HP iPAQ Voice Messenger - Product Guide
  • HP iPAQ Data Messenger - Battery Saving Tips
  • HP iPAQ Data Messenger - Product Guide
Step 4: Calling the HP Support Center
If the device battery continues to drain, call the HP Support Center to replace the battery.
Country: Flag Thailand
