Compaq Presario w185q Monitor - Product Specifications
The Compaq Presario w185q is a 18.5-inch wide-screen monitor with liquid crystal display (LCD) and thin-film transistor (TFT) screen.
Figure : Photo of the Compaq Presario w185q LCD wide-screen monitor
NM972AA
Features
The Compaq Presario w185q LCD wide-screen monitor has the following features:
  • 1366 x 768 factory-set resolution
  • Supports VGA and DVI
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
Technical specifications
LCD feature
Specification
Display size
18.5-inch (46.99 cm) diagonal and viewable image
Display type
Thin-Film Transistor LCD active matrix
Input terminals
1 VGA connector and 1 DVI-D
Integrated speakers
1 watt per channel
Scanning frequency
Horizontal scan range 30-64 KHz
Vertical scan range 50-76 Hz
Viewing angle
Horizontal viewing angle: 170 degrees
Vertical viewing angle: 160 degrees
Recommended resolution (H x V)
1366 x 768 @ 60 Hz
Contrast ratio
Up to 600:1
Response time
5 ms (typical)
Pixel pitch
0.30 mm
Power source - AC/DC adapter
Input rating: 100 to 240V~
frequency: 50~60Hz
Power consumption: 33 watts maximum power consumption in operating mode, <2 W in sleep mode
Operating environment
Temperature: 41 degrees F to 95 degrees F (5 degrees C to 35 degrees C )
Humidity: 15% RH through 90% RH (non-condensing)
Storage environment
Temperature: -29 degrees F to 140 degrees F (-33.8 degrees C to 60 degrees C)
Humidity: 5% RH through 90% RH (non-condensing)
Dimensions
H x W x D (unpacked):
13.54 x 17.4 x 7.09 inches (34.4 x 44.2 x 18 cm)
Unpacked: 7.28 lbs (3.3 Kg)
EMI standard
FCC Class B
Mounting
Standard VESA 4-hole 100 mm x 100 mm
