HP Designjet T1120 MFP Product Series - Calibrate the Touch Screen Pointer
  1. Press Options > Advanced Options > Calibrate screen.
    Figure : Advanced Options dialog
    Access to the Advanced menu may require the system’s administrator password.
  2. Follow the instructions on the screen. Calibration is done by pressing target-points that appear in different positions on the screen. Press the target-points until they no longer appear.
  3. Touch the OK button in the final dialog to confirm and conclude screen calibration.
