HP Designjet T1120 MFP Product Series - Set Input and Output Sizes
This topic describes setting the Scan Area and the Resize options for determining input and output sizes. The Resize setting is only available with Copy tasks.
The "Scan Area", is your input size and defines how much of the image is captured. Often, this will be the total size of the original. However, there may be cases when you only want to scan a portion of the original or wish the capture area to be equal to a certain standard size.
With Copy tasks, you can also determine the output size, i.e., the size of the image in your printed copy through the Resize setting. You can choose "No" resize to use the current Scan Area size for a 1:1 copy or, you can select a different size in order to reduce or enlarge the printed image in relation to the Scan Area size.
With Scan tasks, the image’s size in the output file is always equal to the Scan Area size (1:1).
To set the Scan Area (input size)
When in the Scan or Copy screens, press the Scan Area button to view the Scan Area size list.
Figure : Scan Area dialog screen
The list offers different methods you can use to determine the Scan Area size:
  • Auto: The program will automatically detect the size of the full document loaded in the scanner. Use previewing to verify that the scanner has detected the size as you intended.
  • Use a standard or custom size: The dialog contains a list of standard sizes and custom sizes saved on the system. Scroll through the list and select the size you want to use. To create a new custom size, follow the instructions below.
  • Set size values for width and length: Press the More button to expand the Scan Area dialog. Make your width and length size settings in the fields or set Auto on width or length separately. You can save your changes to create a new custom size or use them for the current job only.
    Figure : Expanded Scan Area dialog screen
You can also set the Scan Area visually on the screen through a Preview. Follow the related topics help link to the topic "How do I preview copies and scans" for instructions about previewing.
To set the Resize value (output size) (Copy task only)
  1. Press the Resize button.
    Figure : Resize dialog screen
    • No (resize) : Select No if you do not want to resize the image i.e., you want the image in the printout to be the same size as the Scan Area.
    • Size: Press the Size button to select a standard size (A4, A2, ISO...) from a list.
    • Scale: Select Scale to resize according to a scale factor (50%, 32%..).
