Service Reference Guide: HP Compaq dx2420 Business PC - Computer Setup (F10) Utility
Computer Setup (F10) Utilities
Use Computer Setup (F10) Utility to do the following:
  • Change factory default settings.
  • Set the system date and time.
  • Set, view, change, or verify the system configuration, including settings for graphics, audio, storage, communications, and input devices.
  • View settings for processor and memory.
  • Modify the boot order of bootable devices such as hard drives, diskette drives, optical drives, or USB flash media devices.
  • Restrict a device from booting the unit.
  • Run hard drive self-tests.
  • Establish a supervisor password that controls access to Computer Setup (F10) Utility and the settings described in this section.
  • Enable or disable removable media boot ability.
Using Computer Setup (F10) Utilities
Computer Setup can be accessed only by turning the computer on or restarting the system. To access the Computer Setup Utilities menu, complete the following steps:
  1. Turn on or restart the computer.
  2. As soon as the computer is turned on, press F10 when the monitor light turns green to enter Computer Setup.
    If you do not press F10 at the appropriate time, you must restart the computer and again press F10 when the monitor light turns green to access the utility.
  3. The Computer Setup Utility screen is divided into menu headings and actions.
    Five menu headings appear on the Computer Setup Utility screen:
    • Main
    • Advanced
    • Power
    • Boot
    • Exit
    Use the arrow keys to select the appropriate heading, then press Enter. Use the arrow (up and down) keys to select the option you want, then press Enter. To return to the previous screen, press Esc.
Do NOT turn the computer power OFF while the ROM is saving the Computer Setup (F10) changes because the CMOS could become corrupted. It is safe to turn off the computer only after exiting the F10 Setup screen.
Computer Setup—Main
Support for specific Computer Setup options may vary depending on the hardware configuration.
Computer Setup—Main
Option
System Time
Allows you to set system time.
System Date
Allows you to set system date.
Language
Allows you to select language.
Floppy Diskette A:
Allows you to set drive A to:
  • Disabled
  • 1.44 MB 3.5”
  • Not Installed
1st Drive
2nd Drive
3rd Drive
4th Drive
For each, allows you to:
  • (view only)
    • Capacity (Size - HDD only)
    • Transfer Mode
    • SATA Speed
    • NCQ
  • Smart Support - run HDD self-test for selected channel:
    • SMART Status Check
    • SMART Short Self-Test
    • SMART Extended Self-Test
System Information
(view only)
  • Installed Memory
  • Memory Bank 1
  • Memory Bank 2
  • Memory Bank 3
  • Memory Bank 4
  • BIOS Revision
  • Core Version
  • Model Number
  • Product Number
  • Asset Tag (press Enter to change)
The model number is programmed by an external utility for the following models:
• HP Compaq dx2390 Microtower
• HP Compaq dx2400 Microtower
• HP Compaq dx2420 Microtower
Computer Setup—Advanced
  warning:
Setting items on this menu to incorrect values may cause your system to malfunction.
Option
CPU Type
(view only)
CPU Speed
(view only)
Cache RAM
(view only)
Primary Video Adapter
Allows you to select the boot display device when more than 2 video options are offered by the system:
  • Integrated (Onboard)
  • PCI
  • PCI-Ex16
  • PCI-Ex1
DVMT Mode Select
Allows you to set video memory mode to:
  • Fixed Mode
  • DVMT Mode
DVMT/Fixed Memory
Allows you to set video memory size to:
  • 128MB
  • 256MB
  • Maximum DVMT (available for DVMT Mode only)
PS/2 Mouse
Allows you to set:
  • Disabled
  • Enabled
  • Auto Detect
USB Legacy Mode Support
Allows you to set:
  • Disabled
  • Enabled
Onboard LAN
Allows you to disable/enable onboard LAN controller.
Onboard LAN Boot ROM
Allows you to disable/enable the boot ROM of the onboard LAN chip.
SATA1 Controller
Allows you to disable/enable the SATA1 Controller.
SATA1 Controller Mode
If SATA1 Controller is enabled, allows you to set the mode to:
  • IDE
  • AHCI
SATA2 Controller
Allows you to disable/enable the SATA2 Controller.
Onboard Audio
Allows you to set the onboard audio to:
  • Auto
  • Disabled
  • Enabled
Internal Speaker
Allows you to set the internal speaker to:
  • Disabled
  • Enabled
Supervisor Password
Allows you to change supervisor password.
User Password
Allows you to change the user password.
Computer Setup—Power
Option
After AC Power Failure
Allows you to select system restart behavior after power loss:
  • Stay Off
  • Power On
  • Auto
XD
Disables/enables XD bit.
Computer Setup—Boot
Computer Setup—Boot
Option
Boot-time Diagnostic Screen
Disables/enables POST diagnostic messages display.
1st Boot Device
2nd Boot Device
3rd Boot Device
4th Boot Device
Allows you to specify which device groups will boot first, second, third, and fourth or to disable any of the four:
  • Floppy Group
  • CD-ROM Group
  • Hard Drive Group
  • Network Boot Group
MS-DOS drive lettering assignments may not apply after a non-MS-DOS operating system has started.
Floppy Group Boot Priority
Specifies boot device priority within removable devices.
CD-ROM Group Boot Priority
Specifies boot device priority within CD/DVD drives.
Hard Drive Group Boot Priority
Specifies boot device priority within hard drives.
Network Group Boot Priority
Specifies boot device priority within bootable network devices.
ESC:Boot Menu
Disables/enables the Esc key boot menu during POST.
F9:Diagnostics
Disables/enables the F9 key diagnostics function during POST.
F10:Setup
Disables/enables the F10 key computer setup function during POST.
F11:Recovery
Disables/enables the F11 key system recovery function during POST.
F12:Boot from LAN
Disables/enables the F12 key boot from LAN during POST.
Computer Setup—Exit
Computer Setup—Exit
Option
Exit Saving Changes
Press Enter to exit saving changes.
Exit Discarding Changes
Press Enter to exit discarding changes.
Load Setup Defaults
Press Enter to load setup defaults.
Discard Changes
Press Enter to discard changes.
Save Changes
Press Enter to save changes.
Recovering the Configuration Settings
To reset all BIOS Setup options to their default values (including options for Ctrl+F10), you must enter F10 Setup mode and press F5.
This does not include updates to system date, system time, supervisor password, user password, and CPU frequency multiplier.
