Adding or Replacing an Expansion Card (Video Card, Sound Card, etc...) in HP and Compaq Desktop PCs
This document pertains only to HP desktop computers with the following computer case:
Image of the computer
Before you begin
  • You need a flathead screwdriver. Note that you need a screwdriver with a long shaft when you are replacing a long graphics card.
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  warning:
Video overview
View the following video before using the steps in this document.
Step 1: Preparing the computer BIOS
Skip this step if you are replacing an existing expansion card and continue with Step 2.
Before starting, if you are adding an expansion card that replaces a function that comes from the motherboard (video, sound, network), disable the on-board function and select the correct BIOS setting in BIOS Setup before attempting to install the new card. Do so as follows:
Step 1
Turn on the computer and, for a Windows Vista computer, immediately begin pressing the F10 key repeatedly until a BIOS Setup screen appears.
If your computer came with Windows XP, press F1 instead of F10.
Step 2
Press the Right arrow key to select the Advanced page.
Step 3
Find and select the setting that matches the type of card you are installing. Examples of what to select for an award BIOS (the BIOS on your computer may be different):
  • Video: Primary Video Adapter
  • Audio: Audio Codec
  • Network: Onboard LAN
Figure : On-board Video example
Image of a BIOS Advanced page with Primary Video Adapter selected
Step 4
Press Enter on the keyboard to open a list of options for the selected function.
Step 5
Select the option that best applies to the expansion card that you will be installing. Examples of what to select:
  • Video: AGP, PCI or PCI-E depending on the type of video card you are installing.
  • Audio: Select disabled if you are installing an audio card. This disables on-board audio, helps prevent conflicts, and saves resources for your new card.
  • Network: Select disabled if you are installing an network card. This disables on-board LAN, helps prevent conflicts, and saves resources for your new card.
    Image of three connector types for Video cards
  1. PCI-E (x16) card
  2. AGP card
  3. PCI card
Step 6
Once you have made your selection by pressing the Enter key, press F10 to Save the settings and exit.
Step 7
Wait while the computer opens into the operating system (Windows). Once Windows fully loads, shut down the computer from the Start menu.
Step 2: Removing the retaining bracket and/or an expansion card
Use the steps in this section to remove the retaining bracket from the computer and to remove an existing card. You must remove the bracket before you can remove or install an expansion card.
  warning:
Step 1
Remove the right side panel.
For more information about removing the side panel, refer to the HP support document Opening the PC Case.
Image of removing the side panel
Step 2
Lay the computer on its side.
Image of laying the computer down
Step 3
Find the expansion cards on the back of the computer. Identify the card you want to replace or the slot that will hold the new card.
Image of the expansion cards on the back of the computer
Step 4
On the back of the computer, remove the screw from the bracket cover for the cards. If it is present, also remove the additional screw that secures a large graphics card.
Image of removing the bracket cover screw
Step 5
Lift off the bracket cover.
If you do not need to remove an existing card and you have a slot available to install the new expansion card, skip to the next section Step 3: Installing an expansion card.
Image of lifting off the bracket cover
Step 6
Identify the type of card you are replacing:
  • For a short or standard-length card, skip to step 12.
  • For a long graphics card, locate the two inside bracket screws near the front of the long graphics card.
The inside bracket for a long graphics card may vary in shape. Your computer may not have an inside bracket or a long graphics card.
Image of the two screws that secure the inside bracket for a long graphics card
Step 7
Remove the two screws that secure the inside bracket in the computer. You may have to move cabling out of the way to reach the lower screw. Note that you need a flathead screwdriver with a long shaft to remove the lower screw.
Image of removing the two screws that secure the inside bracket for a long graphics card
Step 8
Twist the inside bracket clockwise to free the top of the bracket from the drive cage.
Image of twisting the inside bracket to free the top from the drive cage
Step 9
Pull the inside bracket from the computer. You may have to move cables out of the way as you withdraw the bracket.
Image of lifting out the inside bracket
Step 10
Set the bracket aside.
Image of the inside bracket
Step 11
Disconnect the power cable from the long graphics card: Squeeze the latch on the plug, and then pull the plug from the card. Skip to step 13.
Image of removing the graphics card power plug
Step 12
If present, disconnect any cables connected to a short or standard-length card.
Remember where the cables connect. Mark the cables if necessary.
Image of removing a cable to the card
Step 13
Look at the add-in card socket for a release latch, which is present on some sockets.
Some sockets have a release latch that must be disengaged to remove the card from the socket. The release latch style may vary. This example shows a release pad that must be pushed down as you lift the card. A release lever must be pushed out from the socket as you lift the card.
Image of the pad release latch on a socket
Step 14
Remove the card:
  • If there is a release latch, place your finger on the latch and push down on the pad (1) (or out on the lever) as you lift the card (2) from the socket.
    Move the card toward the inside of the computer to free the card external connectors from the computer slot, and then lift the card out of the computer.
Images of the release pad and of removing the card from the socket
Image of moving the card into and out of the computer
  • If there is no release latch, gently rock the card to free it, and then lift the card from the socket.
Image of lifting the card out of the computer
Use the steps in this section to install a new expansion card.
Step 1
To replace a card, skip to step 2.
To add a card into a previously unused slot, remove the slot cover:
Image of a slot cover on the back of the computer
Use a screwdriver to pry off the metal slot cover, being careful to not bend the chassis.
Image of prying off a slot cover
Step 2
For a long graphics card, skip to step 4.
For a short or standard-length card, align the edge of the card with the slot in the computer, and then press the card straight down until it is fully seated in the socket and fills the slot.
Image of pressing the card into the socket
Step 3
Connect any cables to the short or standard-length card. Skip to step 11.
Image of connecting a cable to the card
Step 4
For a long graphics card, lower the card into the computer, then move the card over the socket and toward the open slots.
Image of lowing the card into the computer
Step 5
Place the foot of the card external end into the bottom of the open slots.
Image of the foot of the card placed into the bottom of the open slots
Step 6
Press the card straight down until it is fully seated in the socket and fills the slots.
Image of pressing the card down into the socket
Step 7
Connect the power cable to the long graphics card.
Image of connecting the power cable to the long graphics card
Step 8
...insert the inside bracket over the long graphics card, placing the foot of the bracket over the lower screw hole in the computer. You may have to move cables out of the way as you insert the bracket.
Grasp the inside bracket, and...
Image of the inside bracket for the long graphics card
Image of inserting the inside bracket over the long graphics card
Step 9
Twist the top of the inside bracket counter-clockwise into place over the graphics card power connector and into the drive cage. You may have to press the inside bracket down onto the graphics card and power connector as you twist it to insert the tip of the bracket into the drive cage. Ensure there is nothing between the bracket and the card.
Image of twisting the top of the inside bracket counter-clockwise
Step 10
Insert and tighten the two screws that secure the inside bracket in the computer. Note that you need a flathead screwdriver with a long shaft to insert the lower screw.
Image of inserting the two screws that secure the inside bracket for the long graphics card
Step 11
Look at the outside bracket cover for the two hooks that fit over the two slots on the back of the computer.
Image of the bracket hooks and the slots on the back of the computer
Step 12
Replace the bracket cover onto the back of the computer: Align the bracket cover hooks over the slots on the computer, and then...
Image of aligning the bracket over the computer
...slide the bracket cover into place against the cards.
Image of sliding the bracket cover into place
Step 13
Insert and tighten the bracket cover screw. If it is present, also insert and tighten the additional screw that secures a large graphics card.
Image of inserting the bracket cover screw
Step 14
Set the computer upright.
Image of setting the computer upright
Step 15
Replace the right side panel.
For more information, refer to the HP support document Opening the PC Case.
Image of sliding the side panel toward the front of the computer
