    Fix HP Printer issue on macOS
Blinking Lights on the HP Deskjet D2600 Printer Series
Blinking lights
The lights on the front of the product can be on, off, or blinking (flashing), depending on the status of the product. The lights indicate product status and are useful for diagnosing printing problems.
    Figure : Lights and buttons on the control panel
    Image: Lights and buttons on the control panel
  1. Power light
  2. Resume light
  3. Cancel button
  4. Cartridge Status lights
The following sections describe the most common combinations of blinking lights, followed by solutions for each combination. Find the blinking lights pattern you are experiencing, and then follow the steps to resolve the issue.
