    Fix HP Printer issue on macOS
HP Officejet 4400 (K410), Deskjet Ink Advantage (K209), and Deskjet F4400 and F4500 All-in-One Printer Series - Alignment Page Does Not Print
Issue
After you install new cartridges, the product does not print an alignment page as expected.
Solution one: Make sure the front access door is not open
Check the front access door. If the door is open, close it.
Figure : Close the front access door
llustration of closing the front access door
  • If the alignment page prints automatically, continue to "Solution five, Step two" in this document to complete the alignment process.
  • If the alignment page does not print, continue to the next solution.
Solution two: Check for carriage obstructions
  1. With the product turned on, open the front access door. The carriage moves to the center of the product.
    Figure : Open the front access door
    Illustration of opening the front access door
  2. Inspect the area around the carriage for any obstructions, including packing material. Remove any obstructions.
  3. Close the front access door.
Solution three: Remove and reinsert the cartridges
  1. Make sure the product is on.
  2. Open the front access door.
  3. Wait for the carriage to move to the center of the product.
  4. Press down on one of the cartridges to release it, and then pull it out from its slot.
  5. Hold the cartridge by its sides.
    Figure : Hold the cartridge by its sides
    Illustration of holding the cartridge
  6. Reinsert the cartridge into its designated slot. The black parallelogram icon () designates the slot for the black cartridge, and the magenta half circle icon () designates the slot for the color cartridge.
    Figure : Insert cartridge
    Illustrating of inserting the cartridge
    The cartridge rests in its slot at a slight upward angle.
    Figure : Cartridge rests at upward angle
    Illustration of cartridge resting at upward angle
  7. Press the cartridge in to snap it into place.
    Figure : Snap cartridge into place
    Illustration of snapping the cartridge into place
  8. Repeat these steps to remove and then reinsert the other cartridge.
  9. Close the front access door.
    Illustration of closing the front access door.
Solution four: Reset the All-in-One
Follow these steps to perform a hard reset.
  1. Without turning off the product, disconnect the power cord from the rear of the product.
  2. Wait 30 seconds.
  3. Reconnect the power cord to the rear of the product.
Solution five: Realign the cartridges
Follow these steps to print an alignment page and realign the cartridges.
Step one: Print an alignment page
  1. Make sure you have plain paper loaded in the product.
  2. Open HP Solution Center:
    • Windows XP: Click Start, click All Programs, click HP, and then click HP Solution Center.
    • Windows Vista: Click the Windows icon (), click All Programs, click HP, and then click HP Solution Center.
    HP Solution Center opens in a new window.
  3. In HP Solution Center, click Settings ().
  4. In the Print Settings section, click Printer Toolbox. The printer Toolbox opens in a new window.
  5. Click Align the Print Cartridges ().
  6. Click Print Page. The product prints an alignment page.
    Figure : Product prints an alignment sheet
    Illustration of the product printing an alignment sheet
Step two: Scan the alignment sheet
  1. Lift the product lid.
    Figure : Lift the product lid
    Illustration of lifting the product lid
  2. Place the alignment sheet on with the printed-side down on the right-front corner of the scanner glass. See the engraved guide next to the scanner glass for help loading the alignment sheet.
    Figure : Load the alignment sheet
    Illustration of loading the alignment sheet
  3. Lower the product lid.
    Figure : Lower the lid
    Illustration of lowering the product lid
  4. Press the Scan button () to scan the alignment sheet.
    Figure : Scan the alignment sheet
    Illustration of scanning the alignment sheet
  5. Wait while the product scans the alignment sheet and completes the alignment process.
