HP and Compaq Desktop PCs - Recycle Bin is Missing (Windows Vista)
If the Recycle Bin icon is missing from the Windows desktop, these steps will cause the icon to display.
To automatically cause the Recycle Bin icon to display, click the Microsoft Fix it Solution:
If you cannot use the Microsoft Fix it Solution, use the following steps to manually cause the Recycle Bin icon to display:
  1. Right-click the Windows desktop, and select Personalize.
  2. Click Change Desktop Icons from the left side of the window.
  3. Select Recycle Bin, and click OK.
