HP EliteBook 6930p Notebook PC - Removing and Replacing the Bluetooth Module
This document is provided to assist in removing and replacing the Bluetooth Module for the HP EliteBook 6930p Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head P0 screwdriver.
Parts required
The replacement part number will vary depending on the Bluetooth Module that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Wireless Interface : Integrated wireless Bluetooth 2.0 module
483113-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Bluetooth Module, click on the link below. Or use the product video listing on the HP Services Media Library then select Bluetooth Module from the menu on the upper left hand side of the screen.
Click here to view the Bluetooth Module removal video (right-click on the link to open in a new window/tab).
  2. Loosen the captive P0 Phillips-head screw that secures the Bluetooth cover to the base enclosure.
  3. Lift and remove the Bluetooth cover from the notebook.
  4. Lift the bottom edge of the Bluetooth module until it clears the plastic tab in the base enclosure.
  5. Disconnect the Bluetooth module cable from the Bluetooth module.
  6. Place the Bluetooth module in a static dissipative bag.
Bluetooth Module replacement
  1. Remove the Bluetooth module from the static dissipative bag.
  2. Reconnect the Bluetooth module cable to the Bluetooth module.
  3. Toe the top edge of the Bluetooth module into base enclosure and press down on the bottom edge until the Bluetooth module is secured by the plastic tab in the base enclosure.
  4. Slide the Bluetooth cover onto the base enclosure.
  5. Tighten the captive P0 Phillips-head screw that secures the Bluetooth cover to the base enclosure.
Parts return
