HP EliteBook 6930p Notebook PC - Removing and Replacing the Upgrade Bay Device
This document is provided to assist in removing and replacing the Upgrade Bay Device for the HP EliteBook 6930p Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head P1 screwdriver.
Parts required
The replacement part number will vary depending on the Upgrade Bay Device that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Upgrade bay device
502332-001 (Original)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Upgrade Bay Device, click on the link below. Or use the product video listing on the HP Services Media Library then select Upgrade Bay Device from the menu on the upper left hand side of the screen.
Click here to view the Upgrade Bay Device removal video (right-click on the link to open in a new window/tab).
  2. Loosen the captive, spring-loaded P1 Phillips-head screw that secures the upgrade bay device to the base enclosure.
  3. Use a small, flat-bladed tool to push out on the metal tab on the rear of the upgrade bay device to partially eject it from the base enclosure.
  4. Grasp the upgrade bay device bezel and pull the upgrade bay device out of the base enclosure.
Upgrade Bay Device replacement
  1. Insert the upgrade bay device into the base enclosure until the connector is seated.
  2. Tighten the captive, spring-loaded P1 Phillips-head screw that secures the upgrade bay device to the base enclosure.
Parts return
