Printer Specifications for HP Officejet Pro 8000 and Officejet Pro 8000 Wireless Printers
Product Specifications
Figure : HP Officejet Pro 8000 Series printer
HP Printer models
Some printer features are optional and are not included on every printer model.
Printer model
Part number
HP Officejet Pro 8000 Wireless Printer - A809n
C9297A
C9307A
Cb047A
HP Officejet Pro 8000 Printer - A809a
CB092A
System requirements
Windows
Minimum
Recommended
Windows 2000
Intel Pentium II or Celeron processor
128 MB RAM
150 MB free hard disk space
Internet Explorer 6.0
Adobe Acrobat Reader 5 or later
Intel Pentium III or higher processor
200 MB RAM
Internet Explorer 6.0 or later
Windows XP (32-bit)
128 MB RAM
350 MB free hard disk space
256 MB RAM
370 MB free hard disk space
Microsoft® Windows® x64
AMD Athlon 64, AMD Opteron, Intel Xeon processor with Intel EM64T support, or Intel Pentium 4 processor with Intel EM64T support
128 MB RAM
270 MB free hard disk space
256 MB RAM
390 MB free hard disk space
Windows Vista
800 MHz 32-bit (x86) or 64-bit (x64) processor
512 MB RAM
740 MB free hard disk space
Internet Explorer 7.0
1 GHz 32-bit (x86) or 64-bit (x64) processor
1 GB RAM
1.2 GB free hard disk space
Internet Explorer 7.0 or later
Macintosh
Minimum
Recommended
Mac OS X (10.4.9 and higher, 10.5 and higher)
400 MHz Power PC G3 (v10.4.9 and higher) or 1.83 GHz Intel Core Duo (10.4.9 and higher, 10.5 and higher)
256 MB memory
500 MB free hard disk space
Quick Time 5.0
400 MHz Power PC G4 (v10.4.9 and higher) or 1.83 GHz Intel Core Duo (10.4.9 and higher, 10.5 and higher)
256 MB memory
800 MB free hard disk space
Quick Time 5.0 or later
Processor
384MHz ARM11
Internal memory
  • 32 MB built-in RAM
  • 8 MB built-in MROM + 2 MB built-in Flash ROM
Connectivity
Network support
The product is compatible with the TCP/IP network protocol.
Network operating system compatibility
  • Windows 2000, Windows XP (32-bit), Windows XP x 64 (Professional and Home Editions), WIndows Vista
  • Mac OS X (10.4.x, 10.5)
  • Microsoft Windows 2000 Server Terminal Services with Citrix Metaframe XP with Feature Release 3
  • Microsoft Windows 2000 Server Terminal Services with Citrix Presentation Server 4.0
  • Microsoft Windows 2003 Server Terminal Services
  • Microsoft Windows 2003 Server Terminal Services with Citrix Presentation Server 4.0
  • Microsoft Windows 2003 Server Terminal Services with Citrix Metaframe XP with Feature Release 3
  • Novell NetWare 6, 6.5, Open Enterprise Server 6.5
Embedded Web Server specifications
The Embedded Web Server remotely configures and manages network devices and myPrintMileage. The following are the specifications for the Embedded Web Server.
  • The server requires a TCP/IP-based network. It does not support IPX/SPX-based networks.
  • The server requires a Web browser, either Microsoft Internet Explorer 6.0 or higher, Mozilla Firefox 1.0 or higher, Opera 8.0 or higher, or Safari 1.2, or higher.
  • The server requires a network connection. It cannot be directly connected to a computer with a USB cable.
  • The server requires an Internet connection for some features.
  • The server must be on the same side of a firewall as the product.
USB support
  • USB 2.0 compliant high speed
  • USB host connector is only supported up to full speed
Physical dimensions
Width x depth x height
Device with duplexer: 494 x 180 x 479 mm (19.5 x 7.1 x 18.9 inches)
With Tray 2: 494 x 246 x 479 mm (19.5 x 9.7 x 18.9 inches)
Device with duplexer: 7.2 kg (17.2 lb)
With Tray 2: 9.8 kg (22.9 lb)
Cartridges
Cartridge
Region
Example
Black
Europe
Middle East and Africa
Asia Pacific
HP 940XL* Black Officejet Ink Cartridge
The Americas
HP 940 Black Officejet Ink Cartridge
Cyan
Europe
Asia Pacific
HP 940XL Cyan Officejet Ink Cartridge
The Americas
HP 940 Cyan Officejet Ink Cartridge
Magenta
Europe
Asia Pacific
HP 940XL Magenta Officejet Ink Cartridge
The Americas
HP 940 Magenta Officejet Ink Cartridge
Yellow
Europe
Asia Pacific
HP 940XL Yellow Officejet Ink Cartridge
The Americas
HP 940 Yellow Officejet Ink Cartridge
Visit HP SureSupply to check ink or toner cartridge compatibility or purchase replacement cartridges and other supplies.
  1. If necessary, select your country/region.
    Figure : Country/region selector
    Selecting your country/region
  2. Follow the on-screen instructions to order new supplies or check cartridge compatibility with your printer.
You can also purchase genuine HP cartridges and supplies from other retailers.
Paper-handling specifications
Paper tray capacities
Tray
Type1
Weight2
Capacity
Tray 1
Paper
60 to 105 g/m 2
(16 to 28 lb bond)
Up to 250 sheets
(25 mm or 1 inch stacked)
Transparencies
Up to 70 sheets
(17 mm or 0.67 inch stacked)
Photo paper
280 g/m2
(75 lb bond)
Up to 100 sheets
Envelopes
75 to 90g/m2
(20 to 24 lb bond envelope)
Up to 30 sheets
Cards
Up to 200 g/m2
(110 pound index)
Up to 80 cards
Labels
Up to 100 sheets
Tray 2
Plain paper only
60 to 105 g/m2
(16 to 28 pound bond)
Up to 250 sheets of plain paper
(25 mm or 1.0 inch stacked)
Duplex unit
Paper
60 to 105 g/m2
N/A
Output-bin
All supported media
Up to 150 sheets of plain paper (text printing)
Paper types and sizes
Type
Size
Paper
U.S. Letter: 216 mm (8.5 inches) x 279 mm (11 inches)
A4: 210 mm (8.27 inches) x 297 mm (11.7 inches)
U.S. Executive: 184 mm (7.25 inches) x 267 mm (10.5 inches)
216 mm (8.5 inches) x 330 mm (13 inches)
Legal: 216 mm (8.5 inches) x 356 mm (14 inches)
B5 (JIS): 182 mm (7.17 inches) x 257 mm (10.12 inches)
U.S. Statement: 140 mm (5.5 inches) x 216 mm (8.5 inches)
A5: 148 mm (5.8 inches) x 210 mm (8.3 inches)
Borderless A4: 210 mm (8.3 inches) x 297 mm (11.7 inches)
Borderless A5: 148 mm (5.8 inches) x 210 mm ( 8.3 inches)
Borderless B5 (JIS): 182 mm (7.17 inches) x 257 mm (10.12 inches)
Envelopes
U.S. #10: 105 mm (4.125 inches) x 241 mm (9.5 inches)
Monarch: 98 mm (3.88 inches) x 191 mm (7.5 inches)
HP Greeting Card Envelope: 111 mm (4.38 inches) x 152 mm (6 inches)
A2: 111 mm (4.4 inches) x 146 mm (5.8 inches)
DL: 110 mm (4.3 inches) x 220 mm (8.7 inches)
C5: 162 mm (6.4 inches) x 229 mm (9 inches)
C6: 114 mm (4.5 inches) x 162 mm (6.4 inches)
Japanese Envelope Chou #3: 120 mm (4.7 inches) x 235 mm (9.3 inches)
Japanese Envelope Chou #4: 90 mm (3.5 inches) x 205 mm (8.1 inches)
Cards
Index: 76.2 mm (3 inches) x 127 mm (5 inches)
Index: 102 mm (4 inches) x 152 mm (6 inches)
Index: 127 mm (5 inches) x 203 mm (8 inches)
A6: 105 mm (4.13 inches) x 148.5 mm (5.83 inches)
Borderless A6 card : 105 mm (4.13 inches) x 148.5 mm (5.83 inches)
Hagaki : 100 mm (3.9 inches) x 148 mm ( 5.8 inches)
Ofuku Hagaki: 148 mm (5.8 inches) x 200 mm (7.9 inches)
Photo media
Photo paper: 76.2 mm (3 inches) x 127 mm (5 inches)
Photo paper: 102 mm (4 inches) x 152 mm (6 inches)
Photo paper with tear-off tab: 102 mm (4 inches) x 152 mm (6 inches)
Photo paper with tear-off tab: 102 mm (4 inches) x 203 mm (8 inches)
Borderless photo paper: 102 mm (4 inches) x 152 mm (6 inches)
Borderless photo paper: 127 mm (5 inches) x 178 (7 inches)
Borderless photo paper: 216 mm (8.5 inches) x 279 mm (11 inches)
Other media
Custom-sized media between 76.2 mm (3 inches) to 216 mm (8.5 inches) wide and 127 mm (5 inches) to 356 mm (14 inches) long
Print margins
Left margin
Right margin
Top margin
Bottom margin
U.S. (letter, legal)
U.S. Executive
ISO (A4)
U.S. Statement
8.5 x 13 inch
A5
B5
cards
custom-sized media
photo media
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
Envelopes
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
16.5 mm (0.65 inch)
16.5 mm (0.65 inch)
If using the duplexer to print on both sides of the paper, the minimum top and bottom margins must match or exceed 12 mm (0.47 inch).
Printing specifications
  • Print resolution:
    • Black: Up to 1200 dpi with pigmented black ink
    • Color: HP enhanced photo quality (up to 4800 by 1200 dpi Optimized on HP Premium Plus photo papers with 1200 x 1200 input dpi)
  • Print speed: Up to 14 ppm black and 11 ppm color after first page.
  • Method: drop-on-demand thermal inkjet
  • Language: HP PCL 3 enhanced
  • Duty cycle: Up to 5000 printed pages per month
For more information, go to www.hp.com/go/inkjetprinter.
Power specifications
  • Power supply: Universal power adapter (external)
  • Power consumption: 34.03 watts
  • Input voltage: 100 to 240 VAC (± 10%), 50/60 Hz (± 3Hz)
  • Output voltage: 32 Vdc, 2500 mA
Environmental specifications
Recommended Operating conditions
  • Recommended temperature range: 15° to 32° C (59° to 90° F).
  • Recommended humidity range: is 25 to 75% (noncondensing)
Maximum Operating conditions
The operating temperature range is 5° to 40° C (41° to 104° F).
Storage conditions
  • Storage temperature range: -40° to 60° C (-40° to 140° F)
  • Storage maximum humidity: Up to 90% non-condensing at a temperature of 65° C (150° F).
Energy Star
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products.
Figure : Energy Star
ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information, go to www.energystar.gov.
Material safety data sheets
Click here to get the Material safety data sheets (MSDS).
Ozone production
This product generates no appreciable ozone gas (O3).
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309. Plastic parts over 25 grams are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the product's life.
Recycling program
HP offers an increasing number of product return and recycling programs in many countries/regions and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. More information on HP's recycling programs is available from the HP Web site.
Regulatory specifications
Regulatory model identification number
For regulatory identification purposes, the product is assigned a Regulatory Model Number. The Regulatory Model Number is SNPRC-0702-01, SNPRC-0702-02. This regulatory number should not be confused with the marketing name (HP Officejet Pro 8000) or product number.
FCC Statement
This equipment has been tested and found to comply with the limits for a Class B digital device, according to Part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses, and can radiate radio frequency energy. If it is not installed and used in accordance with the instructions, it might cause harmful interference to radio communications. However, there is no guarantee that interference does not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try correcting the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between equipment and receiver.
  • Connect equipment to an outlet on a circuit different from that to which the receiver is located.
  • Consult a dealer or an experienced radio/TV technician.
Any changes or modifications to the product that are not expressly approved by Hewlett-Packard could void the user's authority to operate this equipment.
