    We are upgrading our website
HP iPAQ Voice Messenger - Using the Pictures and Videos Feature
Viewing pictures and videos stored on the device or a storage card
To view pictures, press Start > Media > Pictures & Videos.
If you are unable to see the Media folder, click Start > All Programs > Media.
To change settings, perform the following steps:
  1. Press Start> Media> Pictures & Videos.
  2. Press Menu> Optionsto change the following settings:
    Figure : Options Screen
    1. General
      • The general settings can be changed to:
        • Large (640 X 480) (default)
        • Medium (320 X 240)
        • Small (160 X 120)
        • Original
      • The orientation of picture can be changed to:
        • Left
        • Right
    2. Slideshow
      • The slide show settings can be changed to:
        • Landscape pictures
        • Portrait pictures
      • Select the Play Screensaver when connected to my PC and idle for 2 minutes check box to make your computer screensaver your iPAQ screensaver.
Viewing a slideshow of the pictures
Follow these steps to view a slideshow:
  1. Press Start > Media > Pictures & Videos.
  2. Press Menu > Play Slideshow.
E-mailing pictures
Configure your e-mail messaging account before sending pictures through e-mail.
When sending an MMS, there may be a 300KB size limitation for the attached file.
Follow these steps to send pictures through e-mail:
  2. Choose the picture to send. Press Menu > Send.
  3. Select the e-mail account to send the picture. Enter the recipient's e-mail address, and the subject, and enter your message, and then press Send.
Associating a contact with a picture
Follow these steps to associate a contact with a picture:
  1. Press Start > Media > Pictures & Videos. Select the picture you want to associate with a contact.
  2. Press Menu > Save to Contact...
  3. Select the contact you want to associate the picture with.
    Figure : Save Contact screen
Assigning a picture to the Home screen background
Follow these steps to assign a picture as the Home screen background:
  2. Select the picture you want to set as the Home screen background and press View.
  3. Press Menu > Use as Home Screen.
    Figure : Use as Home Screen screen
Using the HP Snapfish Upload
The HP Snapfish Upload feature enables you to upload JPEG images from your device to your Snapfish account. This requires an active Internet connection.
Follow these steps to upload the images:
  2. Select the picture to send.
  3. Press Menu > HP Snapfish Upload.
  4. Enter the e-mail address and the password in the respective fields.
  5. Press Send.
    Figure : HP Snapfish Upload screen
    You can use your existing Snapfish account to upload images. If the e-mail account or the password is incorrect, the login fails and returns you to the login screen. If you do not have a Snapfish account, you can go to http://www.snapfish.com/ using your device and register for an account.
Using the HP Enhance Documents feature
Use the document enhancement feature to process an image of a whiteboard, printed document, business card, magazine, or newspaper, to produce scanner-like results.
Follow these steps to use the document enhancement feature:
  1. Press Start > Media > Pictures & Videos. Select the picture to enhance.
  2. Press Menu > HP Enhance Document. Select one or both of the following options:
    • Straighten and crop - To detect the edges of a document and crop the original document to a rectangular shape.
      The document needs to have four well-defined or high-contrast edges.
    • Lighting and color correction - To remove the shading on the surface of the document due to shadows and uneven lighting across the document.
  3. To view the picture in color, select Color or to view the picture in black and white, select Grayscale.
  4. Press Start to begin document processing.
    Figure : HP Enhance Document screen
    The document enhancement feature processes only JPEG images.
Using the camera feature
You can switch to the camera application from the Pictures & Videos option by pressing Start > Media > Pictures & Videos. Select Camera. You can also select Start > All Programs > Camera.
Playing videos
Follow these steps to play videos:
  1. Press Start > Media > Pictures & Videos. Select the video thumbnail to view.
  2. Press Play.
It is recommended that you hold your iPAQ in the horizontal position to capture quality photos and videos.
Country: Flag Thailand
