    Fix HP Printer issue on macOS
HP Compaq dc7800 Small Form Factor Business PC - Spare Parts
Part number and RoHS information
IMPORTANT: Obtaining current part number information
To obtain current part number information for this product, including RoHS-compliant and orderable spare parts, please use one of the following utilities:
  • Click here to go to HP PartSurfer. (To report missing or incorrect parts information in PartSurfer, please use the "Contact us" and "Missing or incorrect data" links within the utility.)
    To lookup RoHS-compliant information in PartSurfer, use the component’s option part number or the sales order number for a system in which the component is used (available in the QuickSpecs or Standard Models page). The spare part number does not provide RoHS-compliant information.
  • Click here to see a list of the Compaq dc7800 models found on the PartSurfer Page. Select the SKU number for a system and get the list of spare part numbers.
System unit
Item number
Part description
Spare part number
1
Front bezel
451148-001
2
Access panel
451141-001
3
Power supply, 240 W
437797-001
4
Power supply, 240 W, 80% efficient
437798-001
5
Bezel blank, 5.25 inches
335937-001
6
Bezel blank, diskette drive
451151-001
7
Tower stand bracket
451150-001
Standard and Optional boards
Item number
Part description
Spare part number
1
Memory modules:
512 MB, PC2-5300, CL5
396520-001
1 GB, PC2-5300, CL5
398038-001
2 GB, PC2-5300, CL5
450367-001
512 MB, PC2-6400, CL6
418952-001
1 GB, PC2-6400, CL6
418951-001
2
Other boards:
Belkin 802.11a/g WLAN adapter for use in the United States and most of the world
391866-002
Belkin 802.11a/g, WLAN adapter for use in the rest of the world
391866-001
nVidia GeForce 8440 GS 256 MB video card with dual-link DVI-I and TV (S-Video) outputs. LP
445743-001
nVidia GeForce 8440 GS 256 MB video card with DMS59 and TV (SVideo) outputs. LP
445744-001
DVI-D ADD2 graphics
398333-001
1394 card 2 external, 1 internal port, FH
393308-001
1394 card 2 external, 1 internal port, LP
393307-001
802.11a/b/g, WLAN PCI card, international, LP
356296-B35
HP dual-band wireless antenna PCI Adapter, LP
435269-001
Intel, Gigabit NIC
398754-001
Broadcom 5751 NetXtreme Gigabit Ethernet Controller, LP
435268-001
Broadcom 5751 NetXtreme Gigabit Ethernet Controller, FH
430654-001
Agere International 56 K Modem
398661-001
ReadyBoost module, 1 GB
455971-001
3
System Boards with thermal grease, alcohol pad, and CPU socket cover:
System board
437793-001
System board, excludes ES/CS
451139-001
4
Intel Celeron Processors with alcohol pad and thermal grease:
440, 512 K cache, 2.00 GHz
449166-001
430, 512 KB cache, 1.8 GHz
449165-001
420, 512 KB cache, 1.8 GHz
449164-001
5
Intel Pentium Dual Core Processors with alcohol pad and thermal grease:
E2180, 1 MB cache, 2.00 GHz
457656-001
E2160, 1 MB cache, 1.80 GHz
457622-001
6
Intel Core 2 Quad Processor with alcohol pad and thermal grease:
Q6700, 8 MB cache, 2.66 GHz
455402-001
Q6600, 8 MB cache, 2.40 GHz
452451-001
7
Intel Core 2 Duo Processors with alcohol pad and thermal grease:
E6850, 4 MB cache, 3.00 GHz
450792-001
E6750, 4 MB cache, 2.66 GHz
450791-001
E6550, 4 MB cache, 2.33 GHz
450694-001
E4500, 2 MB cache, 2.20 GHz
449452-001
E4400, 2 MB cache, 2.00 GHz
449451-001
Cables
Spare part number
Part description
391739-001
SATA HDD cable, 19 inches, 2 straight ends
451143-001
Front I/O with USB and audio cables
453052-001
Serial port cable assembly, 6 inches cable
435263-001
SATA ODD cable, 24 inches, 1 straight, 1 angled end
435261-001
Power/LED cable
454246-001
Diskette drive cable, 6 inches
453317-001
17.7 inches SATA cable, 1 straight end, 1 angled end
Mass storage devices (not illustrated)
Part description
Spare part number
Diskette drive with bezel
431452-001
Media card reader, 3.5 inches
407187-001
Media card reader, 5.25 inches
412838-001
16X SATA DVD±RW and CD-RW drive with LightScribe
447310-001
16X SATA DVD-ROM drive
419496-001
48X CD-RW/DVD-ROM combo drive
419497-001
250 GB, 7200-RPM SATA hard drive, 8 MB cache
449980-001
160 GB, 7200-RPM SATA hard drive, 8 MB cache
449979-001
160 GB, 10000-RPM SATA hard drive, 16 MB cache
439995-001
80 GB, 7200-RPM SATA hard drive, 8 MB cache
449978-001
80 GB, 10000-RPM SATA hard drive, 16 MB cache
439994-001
Miscellaneous parts
Spare part number
Part description
451144-001
Chassis fan
451145-001
Fan duct
453053-001
Fansink with alcohol pad and factory-applied thermal grease
440498-001
Backwall, LP, includes riser card assy
451140-001
Backwall, FH
451149-001
Solenoid lock
453318-001
Heatsink retention plate
370857-001
Power switch/LED holder
417966-001
Mouse, PS2, optical
390937-001
Mouse, scroll
390938-001
Mouse, optical
153099-001
Battery, real-time clock
394779-001
Internal speaker
393601-001
Second serial port, LP
392414-001
Second serial port, FH
198220-001
Modem cable
