HP LaserJet P2030 Series Printer - Special paper or print media guidelines
This product supports printing on special media. Use the following guidelines to obtain satisfactory results. When using special paper or print media, be sure to set the type and size in your print driver to obtain the best print results.
HP LaserJet printers use fusers to bond dry toner particles to the paper in very precise dots. HP laser paper is designed to withstand this extreme heat. Using inkjet paper not designed for this technology could damage your printer.
Media type
Do
Do not
Envelopes
  • Store envelopes flat.
  • Use envelopes where the seam extends all the way to the corner of the envelope.
  • Use peel-off adhesive strips that are approved for use in laser printers.
  • Do not use envelopes that are wrinkled, nicked, stuck together, or otherwise damaged.
  • Do not use envelopes that have clasps, snaps, windows, or coated linings.
  • Do not use self-stick adhesives or other synthetic materials.
Labels
  • Use only labels that have no exposed backing between them.
  • Use Labels that lie flat.
  • Use only full sheets of labels.
  • Do not use labels that have wrinkles or bubbles, or are damaged.
  • Do not print partial sheets of labels.
Transparencies
  • Use only transparencies that are approved for use in laser printers.
  • Place transparencies on a flat surface after removing them from the product.
  • Do not use transparent print media not approved for laser printers.
Letterhead or preprinted forms
  • Use only letterhead or forms approved for use in laser printers.
  • Do not use raised or metallic letterhead.
Heavy paper
  • Use only heavy paper that is approved for use in laser printers and meets the weight specifications for this product.
  • Do not use paper that is heavier than the recommended media specification for this product unless it is HP paper that has been approved for use in this product.
Glossy or coated paper
  • Use only glossy or coated paper that is approved for use in laser printers.
  • Do not use glossy or coated paper designed for use in inkjet products.
