HP iPAQ Voice Messenger - Items Shipped in the Box
The following items are shipped in the box that comes with the HP iPAQ Voice Messenger devices.
Box contents might vary by model.
Item
Getting Started CD with additional software
1260 mAh Li-polymer removable/rechargeable battery
Quick Start Guide
User Manual
AC adapter
The AC adapter shipped with your iPAQ might vary depending on the country/region.
Micro-USB synchronization cable
2.5 mm wired stereo headset
You can increase and enjoy the comfort value of your device by using extended batteries, protective cases, and car cradles. Please check your local HP Web site for details. You can easily access your local HP Web site by selecting your country on the HP home page, http://www.hp.com.
