    Fix HP Printer issue on macOS
HP Compaq dc5850 Small Form Factor Business PC Product Specifications
Product description
The HP Compaq dc5850 Small Form Factor Business PC Series offers the high-end capabilities needed for uncompromising results and the energy efficiencies required to help reduce costs.
Product features
Feature
AMD 780V chipset
Processors
AMD Sempron Processors with HyperTransport Technology:
  • AMD Sempron LE-1300 Processor (2.3 GHz, 512 K L2 cache, HT bus 1.0)
  • AMD Sempron LE-1250 Processor (2.2 GHz, 512 K L2 cache, HT bus 1.0)
AMD Athlon Single-Core Processors with HyperTransport Technology:
  • AMD Athlon LE-1640B Processor (2.7 GHz, 512 K L2 cache, HT bus 2.0)
AMD Athlon Dual-Core Processors with HyperTransport Technology:
  • AMD Athlon X2 5400B Processor (2.8 GHz, 1 MB L2 cache, HT bus 2.0)
  • AMD Athlon X2 5200B Processor (2.7 GHz, 1 MB L2 cache, HT bus 2.0)
  • AMD Athlon X2 5000B Processor (2.6 GHz, 1 MB L2 cache, HT bus 2.0)
  • AMD Athlon X2 4450B Processor (2.3 GHz, 1 MB L2 cache, HT bus 2.0)
AMD Phenom Triple-Core Processors with HyperTransport Technology:
  • AMD Phenom X3 8600B Processor (2.3 GHz, 1.5 MB Dedicated L2 cache, 2 MB Shared L3 cache, HT bus 3.0)
AMD Phenom Quad-Core Processors with HyperTransport Technology:
  • AMD Phenom X4 9600B Processor (2.3 GHz, 2 MB Dedicated L2 cache, 2 MB Shared L3 cache, HT bus 3.0)
Memory
DDR2 SYNCH DRAM NON-ECC MEMORY
Diskette Drive
1.44 MB Diskette Drive
Optical drive
  • SATA DVD-ROM Drive
  • SATA CD-RW/DVD-ROM Combo Drive
  • SATA SuperMulti LightScribe DVD Writer Drive
Media Card Reader
HP 16-in-1 Media Reader (USB connection on the system board)
NIC
  • Integrated Broadcom Gigabit Ethernet (integrated on system board)
  • Broadcom NetXtreme Gigabit Ethernet PCIe NIC Card
Wireless
Wireless A+G PCI Card (low profile bracket)
Modem
2006 Agere PCI 56K International SoftModem (low profile)
Graphics
  • Integrated ATI Radeon 3100 Graphics (with DirectX 10 technology)
  • NVIDIA GeForce 8400 GS 256 MB SH PCIe x16 Graphics Card
  • ATI Radeon HD 2400 XT 256 MB DH PCIe x16 Graphics Card
Keyboard/Mouse
Keyboard:
  • HP PS/2 Standard Keyboard
  • HP USB Standard Keyboard
Mouse:
  • USB 2-Button Laser Mouse
  • PS/2 2-Button Optical Scroll Mouse
  • USB 2-Button Optical Scroll Mouse
Power Supply
240 W BTX power supply – Active PFC 115 v/230 v line switch
Communications
Features
Communication
Wireless LAN:
  • HP Wireless A+G PCI Card (North America only)
  • HP Wireless A+G PCI Card (WW except North America)
  • HP BT450 USB Bluetooth Wireless Printer and PC Adapter
NICs:
  • Intel PRO/1000 PT PCIe Gigabit NIC Card
Modem:
  • Agere 2006 PCI 56K International Modem
Graphics
Single head solutions:
  • NVIDIA GeForce 8400 GS 256MB SH PCIe x16 Graphics Card*
* 1 GB of system memory required. Graphics cards use part of the total system memory to enhance graphics performance.
Multi head solutions:
  • HP DMS59 DVI Dual-head Connector Cable
  • HP DVI to DVI Cable
  • NVIDIA Quadro NVS 290 256MB DH PCIe x16 Graphics Card
  • NVIDIA GeForce 8400 GS 256MB DH PCIe x1 Graphics Card*
Modem
2006 Agere PCI 56K International SoftModem (full height)
Security
  • Kensington lock
  • HP Business PC Security Lock
  • HP ProtectTools Client Security Software including
  • HP 2007 Wall Mount/Security Sleeve
  • HP USB Biometric Fingerprint Reader
  • HP USB Smartcard Keyboard
Audio
Features
Audio
  • Integrated High Definition audio with ADI1884 codec (all ports are stereo)
  • Microphone and Headphone front ports
  • Line-out and Line-In rear ports*
  • Multistreaming capable*
  • Internal Speaker
* Rear audio input port is re-taskable as Line-in or Microphone-in. External speakers must be powered externally. Multistreaming can be enabled in the ADI control panel to allow independent audio streams to be sent to/from the front and rear jacks. This allows for different audio applications to use separate audio ports on the system. For example, the front jacks could be used with a headset for a communications application while the rear jacks are being used with external speakers and a multimedia application.
Physical specifications
Features
Chassis Dimensions (HxWxD)
3.95 x 13.3 x 14.9 inches (10.03 x 33.78 x 37.85 cm)
System weight
16.76 lb (7.62 kg)
System volume
782.77 cu in
Temperature Range
Operating: 50 degree to 95 degree F (10 degree to 35 degree C)*
Non-operating: -22 degree to 140 degree F(-30 degree to 60 degree C)
* Operating temperature is de-rated 1.0 deg C per 300 m (1000 ft) to 3000 m (10,000 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10 deg C/Hr. The upper limit may be limited by the type and number of options installed.
Relative Humidity
Operating: 10% to 90% (non-condensing at ambient)
Non-operating: 5% to 95% (non-condensing at ambient)
Maximum Altitude (unpressurized)
Operating: 10,000 ft (3048 m)
Non-operating: Non-operating: 30,000 ft (9144 m)
Power
240 W power supply - active PFC
Software/OS
Feature
Operating System
  • Microsoft Windows XP
  • Windows Vista
Warranty information
HP Services includes a one-year standard parts and labor warranty, pick-up or carry-in, and toll-free 7 x 24 hardware technical phone support. On-site service and warranty upgrades are also available.
