HP Color LaserJet CP3525 Series Printer - Product updates
This product has remote firmware update (RFU) capability. Use this information to upgrade the product firmware.
Determine the current firmware version
  1. Press the Menu button .
  2. Press the down arrow to highlight the INFORMATION menu, and then press the OK button.
  3. Press the down arrow to highlight the PRINT CONFIGURATION option, and then press the OK button to print.
The firmware datecode is listed on the Configuration page in the section called Device Information. The firmware datecode has this format: YYYYMMDD XX.XXX.X.
  • The first string of numbers is the date, where YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode that begins with 20061125 represents November 25, 2006.
  • The second string of numbers is the firmware version number, in decimal format.
Download new firmware from the HP Web site
To find the most recent firmware upgrade for the product, go to www.hp.com/go/cljcp3525_firmware. This page provides instructions for downloading the new firmware version.
Transfer the new firmware to the product
The product can receive an .RFU file update when it is in a "ready" state.
The following conditions can affect the time required to transfer the file.
  • The speed of the host computer that is sending the update.
  • Any jobs that are ahead of the .RFU job in the queue are completed before the update is processed.
  • If the process is interrupted before the firmware is downloaded, you must send the firmware file again.
  • If power is lost during the firmware update, the update is interrupted and the message Resend upgrade appears (in English only) on the control-panel display. In this case, you must send the upgrade by using the USB port.
The firmware update involves a change in the format of nonvolatile random-access memory (NVRAM). Any menu settings that are changed from the default settings might return to default settings and must be changed again if you want settings that are different from the defaults.
Use the HP Easy Firmware Upgrade utility to update the firmware
This product has flash-based memory, so you can use the .EXE file to upgrade the firmware. Download this file from www.hp.com/go/cljcp3525_firmware.
To use this method, install the printer driver for this product on your computer and then connect the product directly to your computer through a USB cable. Alternatively, have the customer download the utility, so they can use it whether the product is directly connected to their PC or connected through the network.
Depending on the speed of your PC, the firmware upgrade process can be complete on the product, before the progress bar on the screen completes. Once the upgrade process has started, do not use your PC for other activity until the process is complete.
  1. Download the HP Easy Firmware Upgrade utility file to the desktop.
  2. Click the HP Easy Firmware Upgrade utility file. A dialog box with the name of the printer opens.
  3. Ensure the product to be upgraded is in a Ready state.
  4. Select the product to upgrade. If the product is not listed, install a print driver for the product and make sure you can print to the product using the printer driver before continuing.
  5. Click the Send Firmware button. The progress bar moves to the right indicating information is being transferred.
    Do not turn off the product or the PC during this process, or the product may become unstable and unusable. Be aware that an upgrade may require more than ten minutes to complete.
  6. On the PC, a smiling face icon displays in the HP Easy Firmware Upgrade utility dialog box upon a successful firmware download.
    Depending on the speed of your PC, the firmware upgrade may complete before the progress bar on the screen completes. When the upgrade process is complete, the product will reboot.
  7. When the product is back online, print a configuration page to verify that the new firmware has been installed.
Use FTP to upload the firmware through a browser
  1. Make sure the Internet browser you are using is configured for viewing folders from FTP sites. These instructions are for Microsoft Internet Explorer.
    1. Open the browser and click Tools, and then click Internet Options.
    2. Click the Advanced tab.
    3. Select the box labeled Enable folder view for FTP sites.
    4. Click OK.
  2. Print a configuration page and note the TCP/IP address.
  3. Open a browser window.
  4. In the address line of the browser, type ftp://<ADDRESS>, where <ADDRESS> is the address of the product. For example, if the TCP/IP address is 192.168.0.90, type ftp://192.168.0.90.
  5. Locate the downloaded .RFU file for the product.
  6. Drag and drop the .RFU file onto the PORT icon in the browser window.
The product turns off and then on automatically to activate the update. When the update process is complete, a Ready message displays on the product control panel.
Use FTP to upgrade the firmware on a network connection
  1. Take note of the IP address on the HP Jetdirect page. The HP Jetdirect page is the second page that prints when you print the configuration page.
    Before upgrading the firmware, make sure that the product is not in Sleep mode. Also make sure that any error messages are cleared from the control-panel display.
  2. Click Start, click Run, and then type cmd to open the command window.
  3. Type: ftp <TCP/IP ADDRESS>. For example, if the TCP/IP address is 192.168.0.90, type ftp 192.168.0.90.
  4. Go to the folder where the firmware file is stored.
  5. Press Enter on the keyboard.
  6. When prompted for the user name, press Enter.
  7. When prompted for the password, press Enter.
  8. Type bin at the command prompt.
  9. Press Enter. The message 200 Types set to I, Using binary mode to transfer files appears in the command window.
  10. Type put and then the file name. For example, if the file name is cljcp3525.rfu, type put cljcp3525.rfu.
  11. The download process begins and the firmware is updated on the product. This can take several minutes. Let the process finish without further interaction with the product or computer.
    The product automatically turns off and then on again after processing the upgrade.
  12. At the command prompt, type: bye to exit the ftp command.
  13. At the command prompt, type: exit to return to the Windows interface.
Use HP Web Jetadmin to upgrade the firmware
To learn how to use HP Web Jetadmin to upgrade the product firmware, go to www.hp.com/go/webjetadmin
Use Microsoft Windows commands to upgrade the firmware
To update the firmware by using a network connection, follow these instructions.
  1. Click Start, click Run, and then type cmd to open the command window.
  2. Type the following: copy /B <FILENAME> \\<COMPUTERNAME>\<SHARENAME>, where <FILENAME> is the name of the .RFU file (including the path), <COMPUTERNAME> is the name of the computer from which the product is being shared, and <SHARENAME> is the product share name. For example: C:\>copy /b C:\cljcp3525.rfu \\YOUR_SERVER\YOUR_COMPUTER.
    If the file name or path includes a space, you must enclose the file name or path in quotation marks. For example, type: C:\>copy /b "C:\MY DOCUMENTS\cljcp3525.rfu" \\YOUR_SERVER\YOUR_COMPUTER.
  3. Press Enter on the keyboard. The control panel shows a message that indicates the progress of the firmware upgrade. At the end of the upgrade process, the control panel shows the Ready message. The message One File Copied appears on the computer screen.
Upgrade the HP Jetdirect firmware
The HP Jetdirect network interface in the product has firmware that can be upgraded separately from the product firmware. This procedure requires that you install HP Web Jetadmin Version 8.x or later on your computer. See Use HP Web Jetadmin software. Complete the following steps to update the HP Jetdirect firmware by using HP Web Jetadmin.
  1. Open the HP Web Jetadmin program.
  2. Open the Device Management folder in the drop-down list in the Navigation panel. Navigate to the Device Lists folder.
  3. Select the product that you want to update.
  4. In the Device Tools drop-down list, select the Jetdirect Firmware Update option.
  5. Under the Jetdirect Firmware Version heading the HP Jetdirect model number and current firmware version are listed. Make a note of these.
  6. Scroll down to the list of HP Jetdirect model numbers and find the model number you wrote down.
  7. Look at the current firmware version for the model, and see if it is later than the version you wrote down. If it is, right-click on the firmware link, and follow the instructions on the Web page to download the new firmware file. The file must be saved into the <drive>:\PROGRAM FILES\HP WEB JETADMIN\DOC\PLUGINS\HPWJA\FIRMWARE\JETDIRECT folder on the computer that is running the HP Web Jetadmin software.
  8. In HP Web Jetadmin, return to the main product list and select the digital sender again.
  9. In the Device Tools drop-down list, select the Jetdirect Firmware Update option again.
  10. On the HP Jetdirect firmware page, the new firmware version is listed under the Jetdirect Firmware Available on HP Web Jetadmin heading. Click the Update Firmware Now button to update the Jetdirect firmware.
You can also use FTP or the HP Jetdirect Embedded Web Server to update the HP Jetdirect firmware. For more information, go to http://www.hp.com/go/wja_firmware.
Country: Flag Thailand
