    Fix HP Printer issue on macOS
HP iPAQ 300 Travel Companion Series - Synchronization of Contacts on the Device Without Using the Content Manager
Issue:
This document provides information on the synchronization of contacts on a HP iPAQ 300 Travel Companion series device without using the Content Manager.
Solution
It is necessary to download the Content Manager from www.hp.com/support because the Content Manager has the drivers for the iPAQ so that it can be synchronized.
After downloading the Content Manager, follow the steps to synchronize the contacts without using the Content Manager:
Tap Start > All programs > HP iPAQ Travel companion 310 series > Outlook sync > Start.
This will synchronize the contacts on the device with the computer.
