    Fix HP Printer issue on macOS
HP Designjet Z3200PS Printer Series - The printer's internal prints
The internal prints give various kinds of information about your printer. They can be requested from the front panel without using a computer.
Before requesting any internal print, make sure that paper is loaded (roll or sheet), and that the front panel displays the Ready message. The loaded paper should be at least A3 landscape (16.53 in or 42 cm wide); otherwise the print may be clipped.
To print any internal print, select the Internal Prints menu icon , then select the internal print you want. The following internal prints are available.
  • Demo prints: show some of the capabilities of the printer
    • Print black and white photo
    • Print color photo
    • Print color design demo
    • Print GIS map
    Demo prints are printed the same size as the loaded paper.
    If you perform a secure disk erase, see Secure Disk Erase, the demo prints are erased and they are no longer available.
  • Menu map: shows details of all the front-panel display menus
  • Configuration: shows all the current front-panel display settings
  • Usage report: shows estimates of the total number of prints, number of prints by paper type, number of prints by print-quality option and total amount of ink used per color (the accuracy of these estimates is not guaranteed)
  • Service information: provides information needed by service engineers
  • PostScript font list: shows PostScript fonts available
