HP Compaq nx6110 Notebook PC - Removing and Replacing the Fan
This document is provided to assist in removing and replacing the HP Compaq nx6110 Notebook PC for the Fan.
Tools required
P0 Phillips-head screw driver
Parts required
The replacement part number will vary depending on the Fan that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Cooling Fan assembly
378233-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Fan, click on the link below. Or use the product video listing on the HP Services Media Library, then select Fan from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
Fan removal
  2. Disconnect the fan cable from the system board.
  3. Loosen the two captive P0 Phillips-head screws that secure the fan to the base enclosure.
  4. Lift and remove the fan.
Fan replacement
  1. Place the fan into the base enclosure.
  2. Tighten the two captive P0 Phillips-head screws that secure the fan to the base enclosure.
  3. Reconnect the fan cable to the system board.
Parts return
