    Fix HP Printer issue on macOS
Printer Specifications for HP Color LaserJet CP1514n, CP1515n and CP1518ni Printers
Product specifications
Review the following sections for product-specific information.
Figure : HP Color LaserJet CP1514n, CP1515n and CP1518ni Printers
Models and part numbers
HP Color LaserJet models
Part numbers
CC510A
HP Color LaserJet CP1515n
CC377A
HP Color LaserJet CP1518ni
CC378A
System requirements
Component
Windows Computer
Macintosh
  • Windows 2000
  • Windows XP (32- and 64-bit)
  • Windows Server 2003
  • Windows Vista (32- and 64-bit)
  • Windows 7 (32- and 64-bit)
Mac OS X v10.2.8 and later
Processor
Pentium II Celeron
PowerPC G3, G4, G5 or Intel Core processor
RAM
Minimum: 512 MB RAM
Minimum: 256 MB RAM
Free disk space
350 MB disk space
150 MB disk space
CD drive
4 x
4 x
Connectivity
Hi-Speed 2.0 USB port
USB: 2.0 Hi-speed compliant cable*
Browser
Your computer must have one of the following browsers installed:
  • Microsoft Internet Explorer 5.5 or later
  • Netscape Navigator 7.0 or later
  • Opera Software ASA Opera 6.05 or later
Macintosh OS Safari
Other recommended components
Adobe Acrobat 4.0 or later
* A standard USB cable can be purchased from any reputable dealer.
Physical dimensions
Dimension
Measurement
Height
254 mm (10.0 inches)
Width
399 mm (15.7 inches)
Depth
452 mm (17.8 inches)
18.2 kg (40.02 pounds)
Cartridges
Region
Black cartridge
Cyan cartridge
Magenta cartridge
Yellow cartridge
The Americas
Europe
Middle East and Africa
HP 125A Black
HP 125A Cyan
HP 125A Magenta
HP 125A Yellow
Asia Pacific
HP CB540A Black
HP CB541A Cyan
HP CB543A Magenta
HP CB542A Yellow
Paper-handling specifications
The following tables contain specifications for supported paper.
Paper-tray capacities
Capacity can vary depending on paper weight and thickness, and environmental conditions.
Type
Capacity Input tray
Capacity Output tray
  • Plain
  • Letterhead
  • Color
  • Preprinted
  • Prepunched
  • Recycled
60 to 90 g/m2 (16 to 24 lb)
  • Tray 1: single sheet only
  • Tray 2: up to 150 sheets of paper
125 (20 lb paper)
  • Thick paper
  • Glossy paper
  • Cover paper
  • Photo paper
Up to 200 g/m2 (53 lb)
  • Tray 2: up to 15 mm (0.6 inches) stack height
n/a
Envelopes
90 g/m2 (24 lb)
  • Tray 1: single envelope only
  • Tray 2: up to 10 envelopes
n/a
Postcards
  • Tray 1: single card only
  • Tray 2: up to 50 cards
n/a
Transparency films
Thickness: 0.12 to 0.13 mm (4.7 to 5.1 mils)
  • Tray 2: up to 50 sheets of paper
n/a
Labels
Thickness: up to 0.23 mm (9 mils)
n/a
Paper types and sizes
The product supports a wide range of standard and custom sizes of paper. Check the printer driver for supported sizes.
Type
Size
Paper
Letter: 216 x 279 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
Executive: 184.2 x 266.7 mm (7.25 x 10.5 inches)
A4: 210 x 297 mm (8.27 x 11.7 inches)
A5: 148 x 210 mm (5.83 x 8.27 inches)
A6: 105 x 148 mm (4.13 x 5.83 inches)
B4: (JIS) 257 x 364 mm (10.12 x 14.33 inches)
B5: (JIS) 182 x 257 mm (7.17 x 10.12 inches)
16k: 197 x 273 mm (7.75 x 10.75 inches)
8.5 x 13: 216 x 330 mm (8.5 x 13 inches)
4 x 6: 107 x 152 mm (4 x 6 inches)
5 x 8: 127 x 203 mm (5 x 8 inches)
10 x 15 cm: 100 x 150 mm (3.9 x 5.9 inches)
Custom: (76 - 216) x (127 - 356) mm ((3 - 8.5) x (5 - 14) inches)
Envelopes
U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
B5: 176 x 250 mm (6.7 x 9.8 inches)
C5: 162 x 229 mm (6.93 x 9.84 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
Monarch: 98 x 191 mm (3.9 x 7.5 inches)
Postcards
100 x 148 mm (3.94 x 5.83 inches)
148 x 200 mm (5.83 x 7.87 inches)
Transparency films
Labels
Photo (matte or glossy laser photo paper only)
102 x 152 mm (4 x 6 inches)
Custom
Printing specifications
Specification
Details
Print quality, black
Up to 600 x 600 dpi
Print quality, color
Up to 600 x 600 dpi
Resolution technology
HP ImageREt 2400, Ultraprecise toner, HP edge-enhancement
Language
HP PCL 6, HP PCL 5c, HP postscript level 3 emulation, Hybrid print path
Print speed
  • Black and white: up to 12 pages per minute
  • Color: up to 8 pages per minute
First page out
  • As fast as 25.5 seconds
  • As fast as 31.5 seconds
Monthly duty cycle
Up to 30,000 sheets of paper
Duty cycle is the maximum number of pages per month of printed output. This value provides a comparison of product robustness in relation to other HP products, and enables appropriate deployment of printers and MFPs to satisfy the demands of connected individuals or groups.
Recommended monthly print volume
250 - 1000 sheets of paper
HP recommends that the number of printed pages per month be within the stated range for optimum device performance, based on factors including supplies replacement intervals and device life over an extended warranty period.
Duplex printing (printing on both sides of paper)
Manual (driver support provided)
Memory card specifications
The HP Color LaserJet CP1515n does not support memory cards.
Maximum recommended number of files on a memory card
Maximum recommended individual file size
2000
8 MB
Approaching any of the recommended maximums on a memory card might slow the performance of the product.
Supported memory card types
CompactFlash Type 1 and 2
Memory Stick Duo
Memory Stick
Memory Stick Pro
Secure Digital
MultiMediaCard (MMC)
XD-Picture Card
Other memory cards, including Memory Stick Magic Gate Duo, Memory Stick Duo, and Secure Multimedia Card, are supported with the use of an adapter. See the instructions that came with your memory card for more information.
Power specifications
The following tables contain the power specifications for the product.
Power requirements are based on the country/region where the printer is sold. Do not convert operating voltages. Doing so might damage the printer and void the product warranty.
Specification
110-volt models
220-volt models
Power requirements
  • 100 to 127 V (+/-10%)
  • 50 to 60 Hz (+/-2 Hz)
  • 220 to 240 V (+/-10%)
Minimum recommended circuit capacity
4.5 A
2.5 A
Environmental specifications
The following information contains the environmental specifications for the product.
Recommended operating conditions
Environment
Recommended
Allowed
Temperature
17 to 25 °C (62.6 ° to 77 °F)
15 to 30 °C (59 to 86 °F)
Humidity
20% to 60% relative humidity (RH)
10% to 80% RH
Altitude
Not applicable
0 to 3048 m (0 to 10,000 ft)
Energy Star
This product is designed to reduce power consumption and save natural resources without compromising product performance. It has been designed to reduce total energy consumption both during operation and when the device is not active. This product qualifies for ENERGY STAR®, which is a voluntary program established to encourage the development of energy-efficient office products.
ENERGY STAR is a U.S. registered service mark of the U.S. EPA. As an ENERGY STAR partner, HP has determined that this product meets ENERGY STAR guidelines for energy efficiency.
For more information, go to the Energy Star website (in English).
Materials safety data sheets
To view Material Safety Data Sheets (MSDS), go to http://www.hp.com/go/msds (in English).
Ozone production
This product generates no appreciable ozone gas (O3).
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309 and EN 12281:2002. Plastic parts over 25 grams (0.88 ounces) are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of product life.
Recycling program
HP offers an increasing number of product return and recycling programs in many countries and regions, and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. For more information about the recycling of HP products, go to www.hp.com/go/recycle (in English).
Regulatory specifications
The following information contains the regulatory specifications for the product.
Exposure to radio frequency radiation
The Center for Devices and Radiological Health (CDRH) of the U.S. Food and Drug Administration has implemented regulations for laser products manufactured since August 1, 1976. Compliance is mandatory for products marketed in the United States. The device is certified as a “Class 1” laser product under the U.S. Department of Health and Human Services (DHHS) Radiation Performance Standard according to the Radiation Control for Health and Safety Act of 1968. Since radiation emitted inside the device is completely confined within protective housings and external covers, the laser beam cannot escape during any phase of normal user operation.
  warning:
Using controls, making adjustments, or performing procedures other than those specified in this user guide might result in exposure to hazardous radiation.
