HP Compaq 6730b Notebook PC Specifications
Product description
The HP Compaq 6730b Notebook PC offers costeffective business computing without compromising on performance or connectivity. Also, includes features such as a the latest wireless technologies, enhanced security, and compatibility with a range of HP Universal Accessories.
Product features
Feature
Mobile Intel GE45 Express Chipset ICH9M-Enhanced
This chipset is equivalent to the Intel GM45 Express Chipset, with the addition of support for S-video.
Processors
Intel Core 2 Duo Processor:
  • Intel Core 2 Duo Processor T 9600 (2.80 GHz, 6 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor T 9400 (2.53 GHz, 6 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor P 8600 (2.40 GHz, 3 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor P 8400 (2.26 GHz, 3 MB L2 cache, 1066 MHz FSB)*
* Intel's numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
Memory
Standard: 800 MHz DDR2 SDRAM, two slots supporting dual channel memory 1024 MB, 2048 MB, or 4096 MB
Maximum: Upgradeable to 8192 MB with 4096 MB SODIMMs in slots 1 and 2
Dual-channel: Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Graphics
Mobile Intel Graphics Media Accelerator 4500MHD
Microsoft DirectX 10 capable
Internal:
  • 15.4 inches diagonal WXGA anti-glare (1280 x 800 resolution)
  • 15.4 inches diagonal WXGA BrightView (1280 x 800 resolution)
  • 15.4 inches diagonal WXGA+ anti-glare (1440 x 900 resolution)
External: Up to 32 bit per pixel color depth
  • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
  • DVI-D (single link) video signal available through DVI port in optional HP Docking Station
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Keyboard
The 101/102-key compatible keyboard features an industry standard, full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. U.S. and International key layouts are available. Other features include an integrated numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 19 x 19 mm key pitch (center-to-center spacing), 2.5 mm stroke, and comfort-dished keycaps.
Pointing device
Touchpad with scroll zone, two pick buttons.
Expansion card slots
ExpressCard/54: Supports ExpressCard/54 and ExpressCard/34.
Optional Integrated Smart Card Reader (replaces ExpressCard/54 slot): Compatible with ISO 7816 compliant Smart Cards PC/SC interface support
Storage
Internal Storage Device:
  • 120/160/250 GB 5400 rpm SMART SATA II
  • 160 GB 7200 rpm SMART SATA II
These hard drives are customer removable and will withstand multiple insertion/removal cycles. Up to 10 GB is reserved for the system recovery software.
HP 3D DriveGuard: The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Upgrade Bay Fixed 12.7 mm SATA optical drive :
  • DVD+/-RW SuperMulti DL LightScribe Drive
  • DVD/CD-RW Combo Drive
  • DVD-ROM Drive
Second hard drive: 250 GB 5400 rpm SMART SATA II Hard Drive
Power Supply
  • External 65 W Smart AC adapter, 1.8 mt (6 ft) power cord included
Stand-Alone Power Requirements (AC Power)
  • Nominal Operating Voltage: 18.5 V
  • Average Operating Power: TBD W
  • Max Operating power: < 90 W
Communications
Features
HP Integrated Module with Bluetooth Wireless Technology
  • Bluetooth Specification: 2.0 Compliant
  • Dimensions: 1.02 x 0.55 x 0.22 in (26 x 14 x 5.7 mm)
  • Bluetooth Software Supported:
    • Broadcom Bluetooth for Windows
    • Microsoft Windows XP Bluetooth Software
V.92 56K Data/Fax Modem
Form Factor MDC: 1.5 Daughtercard
Power Management Support: APM Revision 1.2, ACPI
Audio
Features
Audio
  • High Definition Audio support with 24 bit DAC
  • Integrated stereo speakers
  • Integrated microphone
  • Touch-sensitive controls for volume up, volume down, and mute
  • Stereo headphone/line out
  • Stereo microphone in
  • Optional VGA webcam
Power
Features
Power Conservation
  • Intel Display Power Saving technology (models with integrated graphics)
  • Hibernation
  • Standby
  • ACPI compliance
Wireless devices
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Wireless LAN is factory configurable or available as an option to be added later. Broadband Wireless (WWAN) requires Windows Vista Business or Windows XP Professional and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
Features
All 802.11 integrated wireless LAN options
  • Wi-Fi certified
  • Cisco Compatible Extensions support
  • Wired Equivalent Privacy (WEP) support up to 128 bit keys
  • Wi-Fi Protected Access (WPA) and WPA2 support
  • 802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP
  • Advanced Encryption Standard (AES) support
  • Dual antennas integrated in the display enclosure
Intel WiFi Link 5100
Integrated support for 802.11a, b, g, and n draft 2.0* Up to 450 mbps data rate
Broadcom 4322AGN 802.11a/b/g/draft-n Wi-Fi Adapter
Integrated support for 802.11a, b, g, and n draft 2.0* Up to 300 mbps data rate
Broadcom 4312G 802.11b/g WiFi Adapter
Integrated support for 802.11 b and g Up to 54 mbps data rate
Bluetooth Specification v2.0 compliant Works with a wide range of Bluetooth devices
* The specifications for 802.11n draft 2.0 are draft specifications and are not final. If the final specifications differ from the draft specifications, it may affect the ability of the notebook to communicate with other 802.11n WLAN devices. In countries where n draft 2.0 is not allowed, this capability is not enabled.
Features
ExpressCard/54 slot
  • Supports ExpressCard/54 (54 mm x 75 mm x 5 mm)
  • ExpressCard/34 (34 mm x 75 mm x 5 mm)
Physical specifications
Features
Dimensions (H x W x D)
  • 1.32 inches (at front) x 14.02 x 10.46 inches
  • 33.6 mm (at front) x 356.0 mm x 265.4 mm
Starting at 5.93 lb (2.69 kg)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 6-cell battery, hard drive, and optical drive. Weight varies by configuration and components.
Temperature
Operating:
  • 32° degree to 95° degree F (0° degree to 35° degree C) (not writing optical)
  • 41° degree to 95° degree F (5° degree to 35° degree C) (writing optical)
Non-operating: –4° degree to 140° degree F (–20° degree to 60° degree C)
Relative Humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 101.6° degree F (38.7° degree C) maximum wet bulb temperature
Shock
Operating: 125 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude (unpressurized)
Operating: –50 to 10,000 ft (–15.24 to 3,048 m)
Non-operating: –50 to 40,000 ft (–15.24 to 12,192 m)
Software/OS
Feature
Operating System
  • Windows Vista
Warranty information
HP Services includes a one-year standard parts and labor warranty, pick-up or carry-in, and toll-free 7 x 24 hardware technical phone support. On-site service and warranty upgrades are also available.
