HP Compaq 6730b Notebook PC - Overview
Product description
The HP Compaq 6730b Notebook PC offers costeffective business computing without compromising on performance or connectivity. Also, includes features such as a the latest wireless technologies, enhanced security, and compatibility with a range of HP Universal Accessories.
Product features
Feature
Mobile Intel GE45 Express Chipset ICH9M-Enhanced
This chipset is equivalent to the Intel GM45 Express Chipset, with the addition of support for S-video.
Processors
Intel Core 2 Duo Processor:
  • Intel Core 2 Duo Processor T 9600 (2.80 GHz, 6 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor T 9400 (2.53 GHz, 6 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor P 8600 (2.40 GHz, 3 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor P 8400 (2.26 GHz, 3 MB L2 cache, 1066 MHz FSB)*
* Intel's numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
Memory
Standard: 800 MHz DDR2 SDRAM, two slots supporting dual channel memory 1024 MB, 2048 MB, or 4096 MB
Maximum: Upgradeable to 8192 MB with 4096 MB SODIMMs in slots 1 and 2
Dual-channel: Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Graphics
Mobile Intel Graphics Media Accelerator 4500MHD
Microsoft DirectX 10 capable
Internal:
  • 15.4 inches diagonal WXGA anti-glare (1280 x 800 resolution)
  • 15.4 inches diagonal WXGA BrightView (1280 x 800 resolution)
  • 15.4 inches diagonal WXGA+ anti-glare (1440 x 900 resolution)
External: Up to 32 bit per pixel color depth
  • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
  • DVI-D (single link) video signal available through DVI port in optional HP Docking Station
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Keyboard
The 101/102-key compatible keyboard features an industry standard, full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. U.S. and International key layouts are available. Other features include an integrated numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 19 x 19 mm key pitch (center-to-center spacing), 2.5 mm stroke, and comfort-dished keycaps.
Pointing device
Touchpad with scroll zone, two pick buttons.
Expansion card slots
ExpressCard/54: Supports ExpressCard/54 and ExpressCard/34.
Optional Integrated Smart Card Reader (replaces ExpressCard/54 slot): Compatible with ISO 7816 compliant Smart Cards PC/SC interface support
Storage
Internal Storage Device:
  • 120/160/250 GB 5400 rpm SMART SATA II
  • 160 GB 7200 rpm SMART SATA II
These hard drives are customer removable and will withstand multiple insertion/removal cycles. Up to 10 GB is reserved for the system recovery software.
HP 3D DriveGuard: The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Upgrade Bay Fixed 12.7 mm SATA optical drive :
  • DVD+/-RW SuperMulti DL LightScribe Drive
  • DVD/CD-RW Combo Drive
  • DVD-ROM Drive
Second hard drive: 250 GB 5400 rpm SMART SATA II Hard Drive
Power Supply
  • External 65 W Smart AC adapter, 1.8 mt (6 ft) power cord included
Software overview
Feature
Operating System
  • Microsoft Windows XP
  • Windows Vista
Warranty information
HP Services includes a one-year standard parts and labor warranty, pick-up or carry-in, and toll-free 7 x 24 hardware technical phone support. On-site service and warranty upgrades are also available.
Country: Flag Thailand
