HP Compaq 6530s and 6531s Notebook PC Specifications
Product description
The newly-designed HP Compaq 6530s Notebook PC is a comfortable fit for any budget, With the 14.1-inch diagonal widescreen display you choose between an anti-glare display or an HP BrightView display.
Product features
Feature
  • Mobile Intel PM45 Express Chipset with ICH9M, 1066 MHz front side bus (models with discrete graphics)
  • Mobile Intel GM45 Express Chipset with ICH9M, 1066 MHz front side bus (models with integrated graphics)
Processors
Intel Core 2 Duo Processor:
  • Intel Core 2 Duo Processor T9400 (2.53 GHz, 6 MB L2 cache, 1066 MHz FSB)
  • Intel Core 2 Duo Processor P8600 (2.40 GHz, 3 MB L2 cache, 1066 MHz FSB)
  • Intel Core 2 Duo Processor P8400 (2.26 GHz, 3 MB L2 cache, 1066 MHz FSB)
  • Intel Core 2 Duo Processor T5870 (2.00 GHz, 2 MB L2 cache, 800 MHz FSB)
  • Intel Core 2 Duo Processor T5670 (1.80 GHz, 2 MB L2 cache, 800 MHz FSB)
Processor speed denotes maximum performance mode. processors will run at lower speeds in battery optimization mode.
Memory
Standard:
  • 667 MHz or 800 MHz DDR2 SDRAM, two slots supporting dual channel memory
  • 1024 MB or 2048 MB
Maximum: Upgradeable to 8192 MB with 4096 MB SODIMMs in slots 1 and 2
Dual-channel: Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Graphics
Models with discrete graphics: ATI Mobility Radeon HD 3430 graphics with 128/256 MB dedicated video memory.
Models with integrated graphics: Mobile Intel Graphics Media Accelerator X4500 HD graphics.
Microsoft DirectX 10.1.
Internal:
  • 14.1 inches diagonal WXGA anti-glare (1280 x 800 resolution)
  • 14.1 inches diagonal WXGA BrightView (1280 x 800 resolution)
External: Up to 32 bit per pixel color depth
  • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Keyboard
The 101/102-key compatible keyboard features an industry standard, full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. U.S. and International key layouts are available. Other features include an integrated numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 19 x 19 mm key pitch (center-to-center spacing), 2.5 mm stroke, and comfort-dished keycaps.
Pointing device
Touchpad with scroll zone, two pick buttons.
Expansion card slots
ExpressCard/54: slot Supports ExpressCard/54 (54 mm x 75 mm x 5 mm) and ExpressCard/34 (34 mm x 75 mm x 5 mm) card sizes.
Media Card Reader: Supports SD (Secure Digital), MMC (MultiMedia Card), Memory Stick, Memory Stick Pro, Memory Stick Duo, xD-Picture card.
Storage
Internal Storage Device:
  • 120/160/250 GB 5400 rpm SMART SATA Hard Drive
  • 120 GB 7200 rpm SMART SATA Hard Drive (discrete graphics only)
These hard drives are customer removable and will withstand multiple insertion/removal cycles. Up to 10 GB is reserved for the system recovery software.
HP 3D DriveGuard: The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Fixed optical drive:
  • Blu-ray ROM DVD+/-RW SuperMulti DL Drive (discrete graphics only)
  • DVD+/-RW SuperMulti DL LightScribe Drive
  • DVD/CD-RW Combo Drive
  • DVD-ROM Drive
Power Supply
  • External 65 W Smart AC adapter
  • External 90 W Smart AC adapter (discrete graphics only)
Stand-Alone Power Requirements (AC Power)
  • Nominal Operating Voltage: 18.5 V
  • Average Operating Power: 12.5 W
  • Max Operating power: < 90 W
Communications
Features
HP Integrated Module with Bluetooth Wireless Technology
  • Bluetooth Specification: 2.0 Compliant
  • Dimensions: 1.02 x 0.55 x 0.22 in (26 x 14 x 5.7 mm)
  • Bluetooth Software Supported:
    • Broadcom Bluetooth for Windows
    • Microsoft Windows XP Bluetooth Software
V.92 56K Data/Fax Modem
Form Factor MDC: 1.5 Daughtercard
Power Management Support: APM Revision 1.2, ACPI
Audio
Features
Audio
  • High Definition Audio support
  • Integrated stereo speakers
  • Integrated microphone
  • Stereo headphone/line out
  • Stereo microphone in
  • Optional VGA webcam
Power
Features
Power Conservation
  • Intel Display Power Saving technology (models with integrated graphics)
  • ATI PowerPlay technology (models with discrete graphics)
  • Hibernation
  • Standby
  • ACPI compliance
Wireless devices
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Wireless LAN is factory configurable or available as an option to be added later. Broadband Wireless (WWAN) requires Windows Vista Business or Windows XP Professional and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
Features
All 802.11 integrated wireless LAN options
  • Wi-Fi certified
  • Cisco Compatible Extensions support
  • Wired Equivalent Privacy (WEP) support up to 128 bit keys
  • Wi-Fi Protected Access (WPA) and WPA2 support
  • 802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP
  • Advanced Encryption Standard (AES) support
  • Dual antennas integrated in the display enclosure
Intel WiFi Link 5100
Integrated support for 802.11a, b, g, and n draft 2.0* Up to 450 mbps data rate
Broadcom 4321AGN 802.11a/b/g/draft-n Wi-Fi Adapter
Integrated support for 802.11a, b, g, and n draft 2.0* Up to 300 mbps data rate
Broadcom 4311AG 802.11a/b/g WiFi Adapter
Integrated support for 802.11 b and g Up to 54 mbps data rate
Bluetooth Specification v2.0 compliant Works with a wide range of Bluetooth devices
* The specifications for 802.11n draft 2.0 are draft specifications and are not final. If the final specifications differ from the draft specifications, it may affect the ability of the notebook to communicate with other 802.11n WLAN devices. In countries where n draft 2.0 is not allowed, this capability is not enabled.
Features
ExpressCard/54 slot
  • Supports ExpressCard/54
  • ExpressCard/34
Physical specifications
Features
Dimensions (H x W x D)
  • 1.21 inches (at front) x 13.3 x 9.7 inches
  • 30.7 (at front) x 338.0 x 246.4 mm
Starting at 5.0 lb (2.27 kg)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 6 cell battery, 80 GB hard drive, 512 MB memory, and optical drive. Weight varies by configuration and components.
Software/OS
Feature
Operating System
  • Windows Vista
Environmental specifications
Features
Temperature
Operating:
  • 32° degree to 95° degree F (0° degree to 35° degree C) (not writing optical)
  • 41° degree to 95° degree F (5° degree to 35° degree C) (writing optical)
Non-operating: –4° degree to 140° degree F (–20° degree to 60° degree C)
Relative Humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 101.6° degree F (38.7° degree C) maximum wet bulb temperature
Shock
Operating: 125 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude (unpressurized)
Operating: –50 to 10,000 ft (–15.24 to 3,048 m)
Non-operating: –50 to 40,000 ft (–15.24 to 12,192 m)
Warranty information
HP Services includes a one-year standard parts and labor warranty, pick-up or carry-in, and toll-free 7 x 24 hardware technical phone support. On-site service and warranty upgrades are also available.
