HP iPAQ 900 Business Messenger Series - How to Set Up WAP Gateway for Wireless Communication
Issue:
This document describes how to set up a WAP gateway for wireless communication.
Solution
To set up the connection, complete the following steps:
1. Tap Start -> Settings -> Connections -> Advanced -> Select Networks.
2. Select the iPAQ WAP option from the list of the Programs that automatically connect to the Internet.
3. Tap Edit -> Modem.
4. Select the required Internet Service Provider (ISP) from the displayed list, and tap Edit.
5. Type the name of the ISP in the Enter a name for the connection box, and tap Next.
6. Type the access point name of the server to which you are attempting to connect in the Access point name box, and then tap Next.
7. Type the user name and password.
8. Type the domain name, if provided by your ISP.
9. Tap Finish.
