HP Compaq dc7800 Ultra-slim Desktop PC - Removing and Replacing the Access panel
This document pertains only to HP Compaq dc7800 Ultra-slim Desktop PCs with the following case design:
Before you begin
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  • Move the computer to a clear, flat, stable work surface over a non-carpeted floor.
  warning:
Video overview (in English)
To view a video demonstrating the procedure for removing the access panel, right-click Access panel removal video and select Open link in new window/tab.
Replacement part information
The following HP part numbers are known to be compatible with this system:
Part Number
Requires Return
Top access panel - Provides access to the inside of chassis.
451387-001 (Modified)
No
* If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. For more information about returning parts to HP select one of the links below:
Review the following safety considerations before performing the following steps. Failure to comply with these safety considerations could result in damage to the product.
Step 1
Remove the cable lock and/or padlock, if they are installed.
Step 2
Loosen the captive thumbscrew that secures the access panel.
Step 3
Press on the access panel and slide it forward about half an inch.
Step 4
Lift the panel away from the chassis.
Access panel replacement
Step 1
Position the access panel over the chassis about half an inch beyond the front of the computer so that the tabs on the access panel align with the slots on the chassis guide rails.
Step 2
Press on the access panel and slide it back until it is flush with the front bezel.
Step 3
Tighten the thumbscrew.
