    We are upgrading our website
HP LP2475w 24-inch Widescreen LCD Monitor - Cabling
Rear Components
Monitor rear components vary by model.
Figure : Rear Components
Call-out
Component
Function
1
Cable Lock Provision
Provides slot for use with cable security locks.
2
Master Power Switch
Turns Off all power to the monitor.
3
AC Power Connector
Connects the AC power cord to the monitor.
4
DisplayPort Connector
Connects the DisplayPort signal cable to the monitor.
5
HDMI Connector
Connects the HDMI signal cable to the monitor.
6
DVI-I Connectors
Connects the DVI to VGA signal cable or DVI to DVI-D signal cable to the monitor.
7
SPDIF Audio Connector
Connects an audio cable from a digital audio input on an external receiver or amplifier to the monitor.
The SPDIF connector is only used with an HDMI video input. It does not provide audio for other video inputs.
8
S-Video Connector
Connects an S-Video signal cable to the monitor.
9
Composite Connector
Connects a Composite signal cable to the monitor.
10
Component Connectors
Connects Component signal cables to the monitor.
11
USB Upstream Connector
Connects the monitor USB hub cable to a host USB port/hub.
12
USB Downstream Connectors
Connects optional USB devices to the monitor.
13
USB Downstream Connectors (side panel)
Selecting and Connecting the Signal Cables
The monitor signal inputs vary by model. The following table indicates which input video signal is supported on each monitor model.
Refer to Rear Components for signal input connector locations.
The monitor will automatically determine which inputs have valid video signals. The inputs can be selected through the On-Screen Display (OSD) feature by pressing the Input button (HP LP2275w Model) or the Quick Select button (HP LP2475w Model) on the front panel.
Input
Monitor Connector and Cable Plug
Connection Description
DVI-I
(HP LP2275w)
(HP LP2475w)
The video mode supported by the DVI-I connector is determined by the video cable used.
  • For digital operation, use the DVI to DVI-D signal cable provided. Connect the DVI to DVI-D signal cable to the DVI-I connector on the monitor and the other end to the DVI-D connector on the computer.
  • For analog operation, use the DVI to VGA signal cable provided. Connect the DVI to VGA signal cable to a DVI-I connector on the monitor and the other end to the VGA connector on the computer.
DisplayPort
(HP LP2275w)
(HP LP2475w)
Connect the DisplayPort cable provided to the DisplayPort connector on the monitor and the DisplayPort connector on the computer for digital operation.
The DisplayPort cable locks in place when it is connected. To remove a DisplayPort cable, press the button on top of the cable end and pull the cable end from the connector.
HDMI
(HP LP2475w)
Connect the HDMI cable provided to the HDMI connector on the monitor and the HDMI connector on the input device for digital operation.
For audio output from the HDMI signal, connect an audio cable between the SPDIF audio output on the monitor and a digital audio input on an external receiver or amplifier.
SPDIF
(HP LP2475w)
Connect an SPDIF audio cable to the monitor and to an external receiver or amplifier for digital audio when using HDMI video input. Cable purchased separately.
Component (Y Pb Pr)
(HP LP2475w)
Connect a set of Component cables to the Component connectors on the monitor and the Component connectors on the input device for analog operation. Cable purchased separately.
S-Video
(HP LP2475w)
Connect an S-Video cable to the S-Video connector on the monitor and the S-Video connector on the input device for analog operation. Cable purchased separately.
Composite
(HP LP2475w)
Connect a Composite cable to the Composite connector on the monitor and the Composite connector on the input device for analog operation. Cable purchased separately.
