You do not need to exit a program to open another or to conserve memory. The system manages memory automatically. To open a program, tap Start, and then tap the program you want from the list. If the desired program cannot be seen, tap Start > Programs. In most cases, programs automatically stop to free required memory. However, it can be chosen to close programs manually.
- ${title}
- ${title}
- ${title}
- ${title}
HP iPAQ 600 Business Navigator Series - Open and Close Programs and Managing Memory
Details
To close programs, follow these steps:
Tap Start > Settings > System > Memory > Running Programs.
In the Running Programs list, tap the program you want to close, and then tap Stop.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
