HP Pavilion w2216h Monitor - Product Specifications
The HP Pavilion w2216h is a 21.6-inch wide-screen hdmi monitor with liquid crystal display (LCD) and thin-film transistor (TFT) screen.
Figure : Photo of the HP Pavilion w2216h LCD wide-screen hdmi monitor
KQ741AA and KQ741AS
Features
The HP Pavilion w2216h LCD wide-screen hdmi monitor has the following features:
  • BrightView Technology enhances clarity and provides brilliant colors
  • 1680 x 1050 factory-set resolution
  • Video inputs supported:
    • HDMI connector (version 1.1)
    • VGA connector
  • Supports High-bandwidth Digital Content Protection (HDCP) to prevent transmission of non-encrypted high definition content
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Star compliant
Technical specifications
LCD feature
Specification
Display size
21.6-inch (54.8 cm) diagonal and viewable image
Display type
Thin-Film Transistor LCD active matrix
BrightView technology
Input terminal
VGA connector
Other connectors
3.5 mm Stereo mini jack input (for microphone)
Integrated speakers
2 watts per speaker
Scanning frequency
Horizontal scan range 24-83 KHz
Vertical scan range 48-76 Hz
Viewing angle
Horizontal viewing angle: 160 degrees
Vertical viewing angle: 160 degrees
Recommended resolution (H x V)
1680 x 1050 @ 60 Hz
Contrast ratio
Up to 1000:1
Dynamic Contrast ratio
Up to 3000:1
Dynamic Contrast Ratios up to 3000:1 during video playback only, depending on series of frames or time duration.
Response time
5 ms (on-off), 3 ms G-to-G with Overdrive on
Pixel pitch
0.282 mm
HDCP (High-bandwidth Digital Content Protection)
Support for HDCP enables the monitor to display HDTV resolution if connected by the DVI connector. A monitor without HDCP support, or connected by analog VGA, causes the displayed video to be downgraded in quality to a DVD-like resolution that is less than HDTV.
HDCP is also a content protection system. The goal of HDCP is to prevent transmission of non-encrypted high definition content.
Power source - AC/DC adapter
Input rating: 100 to 240V~
frequency: 50~60Hz
Power consumption: 65 watts maximum power consumption in operating mode, <2 watts in sleep mode
Operating environment
Temperature: 41 degrees F to 95 degrees F (5 degrees C to 35 degrees C )
Humidity: 15% RH through 90% RH (non-condensing)
Storage environment
Temperature: -29 degrees F to 140 degrees F (-33 degrees C to 60 degrees C)
Humidity: 5% RH through 90% RH (non-condensing)
Dimensions
H x W x D (unpacked):
18.9 x 20.5 x 11.3 inches (48.1 x 52.3 x 28.7 cm)
Unpacked: 19.8 lbs (9 Kg)
EMI standard
FCC Class B
Mounting
Standard VESA 4-hole 100 mm x 100 mm
EPA Energy Star
As an Energy Star Partner, Hewlett-Packard has determined that this product meets the Energy Star guidelines for energy efficiency.
