HP Compaq dc7800 Small Form Factor PC - Removing and Replacing the Power supply
This document pertains only to HP Compaq dc7800 Small Form Factor PCs with the following case design:
Before you begin
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  • Move the computer to a clear, flat, stable work surface over a non-carpeted floor.
  warning:
Video overview (in English)
To view a video demonstrating the procedure for removing the power supply, right-click Power supply removal video and select Open link in new window/tab.
Replacement part information
The following HP part numbers are known to be compatible with this system:
Part Number
Requires Return
Power supply ? Input voltage 100 to 240 V AC (auto-ranging), 47 to 63 Hz - 6 DC outputs, 240 W - With power factor correction
437797-001 (Modified)
Yes
Power supply ? Input voltage 100 to 240 V AC (auto-ranging), 47 to 63 Hz - 6 DC outputs, 240 W, 80% efficient - With power factor correction
437798-001 (Modified)
Yes
* If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. For more information about returning parts to HP select one of the links below:
Review the following safety considerations before performing the following steps. Failure to comply with these safety considerations could result in damage to the product.
Step 1
With all cables disconnected from the computer, remove the access panel.
Step 2
Rotate the drive cage to the up position.
Step 3
Rotate the power supply to the up position.
Step 4
Remove the power cables from the cable clip under the drive cage.
Step 5
Disconnect the power cables from all of the drives and the system board, noting their location for reinstallation.
Step 6
Rotate the power supply slightly inward and then pull forward to move the smaller guide pins out of the curved channels in the mounting bracket into the vertical channels.
Step 7
Lift the power supply up and out of the mounting bracket.
Power supply replacement
Step 1
Position the power supply with the guide pins over the channels in the mounting bracket.
Step 2
Slide the power supply down and then back toward the rear of the chassis until the smaller guide pins enter the curved channel.
Step 3
Connect all power cables to the drives and system board.
Step 4
Place the power cables into the cable clip under the drive cage.
Step 5
Rotate the power supply to the down position.
Step 6
Rotate the drive cage to the down position.
Step 7
Replace the access panel.
