Printer Specifications for the HP Photosmart D7560 Printer
Product Specifications
Figure : HP Photosmart D7560 printer
HP printer models
Printer model
Part number
Q8441A
System requirements
Component
Windows
Macintosh
Microsoft® Windows XP Home, XP Professional, x64 Edition, or Vista
Mac ®OS X 10.4.x or higher
Processor
Windows XP Home & XP Professional: Any Intel® Pentium® II, Celeron®, or compatible processor, 233 MHz (Pentium III, 300 MHz or higher recommended)
Windows XP x64 Edition: Pentium 4 with Intel EM64T support
Vista: 800 MHz 32-bit (x86) or 64-bit processor (1 GHz or higher recommended)
G3 or greater
RAM
Windows XP Home & XP Professional: 128 MB (256 MB or higher recommended)
Windows XP x64 Edition: 256 MB (512 MB or higher recommended)
Vista: 512 MB (1 GB or higher recommended)
128 MB
Free disk space
400 MB
150 MB
Video display
SVGA 800 x 600, 16-bit color (32–bit color recommended)
800 x 600 pixels, 16-bit or higher
Memory cards
MultiMedia Card (MMC), MMC Plus, Secure MultiMedia Card, MMC Mobile (RS-MMC; adapter required), Secure Digital (SD), Secure Digital Mini, Secure Digital High Capacity (SDHC), TransFlash MicroSD Card (adapter required), or xD-Picture card, CompactFlash (CF) types I and II
Connectivity
Rear USB port
Rear USB port
Browser
Microsoft Internet Explorer 5.5 or later
Not applicable
Physical dimensions
Dimension
Measure
Height
183.2 mm (7.21 inches)
Width
457.9 mm (18.027 inches)
Depth
383.1 mm (15.181 inches)
5.56 kg (12.25 lbs)
Ink cartridges
Visit HP SureSupply to check ink or toner cartridge compatibility or purchase replacement cartridges and other supplies.
  1. If necessary, select your country/region.
    Figure : Country/region selector
    Selecting your country/region
  2. Follow the on-screen instructions to order new supplies or check cartridge compatibility with your printer.
You can also purchase genuine HP cartridges and supplies from other retailers.
Paper-handling specifications
Paper tray capacities
Paper type
Paper weight
Input tray
Output tray
Photo tray
Plain paper
16 to 24 lb. (60 to 90 gsm)
Up to 125 (20 lb. paper)
50 (20 lb. paper)
Not applicable
Legal paper
20 to 24 lb. (75 to 90 gsm)
50 (20 lb. paper)
Not applicable
Cards
110 lb. index max (200 gsm)
Up to 40
25
Up to 20
Envelopes
Up to 15
Not applicable
Transparency film
Not applicable
Up to 40
25
Not applicable
Labels
Not applicable
Up to 40
25
Not applicable
130 x 180 mm (5 x 7 inches) Photo paper
67 lb. Bond (252 gsm)
Up to 40
25
20
100 x 150 mm (4 x 6 inches) Photo paper
Up to 40
25
20
L 89 x 127 mm (3.5 x 5 inches) Photo paper
Up to 40
25
20
Letter 216 x 279 mm (8.5 x 11 inches) / A4 210 x 297 mm (8.27 x 11.69 inches) Photo paper
Up to 40
25
Not applicable
Paper types and sizes
Paper type
Paper size
Copier, multi-purpose, or plain papers
Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm (8.27 x 11.69 inches)
Envelopes
US No.10: 105 x 241 mm (4.12 x 9.5 inches)
A2 invitation: 111 x 146 mm (4.37 x 5.75 inches)
DL: 110 x 220 mm (4.33 x 8.66 inches)
C6: 114 x 162 mm (4.49 x 6.38 inches)
Greeting-card papers
Index cards
Index: 76.2 x 127 mm (3 x 5 inches)
Index: 101.6 x 152 mm (4 x 6 inches)
Index: 127 x 203.2 mm (5 x 8 inches)
A6: 105 x 148.5 mm (4.12 x 5.85 inches)
Inkjet papers
Iron-on T-shirt transfers
Labels
Legal
216 x 356 mm (8.5 x 14 inches)
Letterhead
Panorama photo paper
101.6 x 304.8 mm (4 x 12 inches)
100 x 300 mm (3.94 x 11.81 inches)
Photo papers
100 x 150 mm (4 x 6 inches) (with or without tab)
130 x 180 mcm (5 x 7 inches) (with or without tab)
Transparency films
Custom-size papers
Printing specifications
  • Print speeds vary according to the complexity of the document
  • Panorama-size printing
  • Method: drop-on-demand thermal inkjet
  • Language: PCL3 GUI
Power specifications
The product's power consumption is as follows.
  • Power consumption: 42 watts maximum (average printing)
  • Power adapter input rating: AC 100 to 240 V ~ 1300 mA 50–60 Hz
  • Printer DC rating: DC 32 V===1300 mA
Use only with the power adapter supplied by HP.
Environmental specifications
Recommended operating conditions
Recommended operating temperature range: 15º to 32º C (59º to 90º F)
Maximum operating conditions
Allowable operating temperature range: 5º to 40º C (41º to 104º F)
Humidity: 20% to 80% RH non-condensing
Storage conditions
Non-operating (Storage) temperature range: –20º to 60º C (–4º to 140º F)
In the presence of high electromagnetic fields, it is possible that the output from the HP product might be slightly distorted.
HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields.
Energy star
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products.
Figure : Energy Star
ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information, go to www.energystar.gov.
Material safety data sheets
Click here to get the Material safety data sheets (MSDS).
Ozone production
This product generates no appreciable ozone gas (O3).
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309. Plastic parts over 25 grams are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the product's life.
Recycling program
HP offers an increasing number of product return and recycling programs in many countries/regions and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. More information on HP's recycling programs is available from the HP Web site.
Regulatory specifications
The HP Photosmart meets the product requirements from regulatory agencies in your country/region. For a complete listing of the regulatory notices, see the onscreen Help.
Regulatory model identification number
For regulatory identification purposes, the product is assigned a Regulatory Model Number. The Regulatory Model Number for the product is SDGOB-0822. This regulatory number should not be confused with the marketing name (HP Photosmart D7500 series, etc.) or product numbers (Q8440A, etc.).
FCC statement
This equipment has been tested and found to comply with the limits for a Class B digital device, according to Part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses, and can radiate radio frequency energy. If it is not installed and used in accordance with the instructions, it might cause harmful interference to radio communications. However, there is no guarantee that interference does not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try correcting the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between equipment and receiver.
  • Connect equipment to an outlet on a circuit different from that to which the receiver is located.
  • Consult a dealer or an experienced radio/TV technician.
Any changes or modifications to the product that are not expressly approved by Hewlett-Packard could void the user's authority to operate this equipment.
