HP Compaq dc7800 Convertible Minitower PC - Removing and Replacing the System fan
This document pertains only to HP Compaq dc7800 Convertible Minitower PCs with the following case design:
Before you begin
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  • Move the computer to a clear, flat, stable work surface over a non-carpeted floor.
  warning:
Video overview (in English)
To view a video demonstrating the procedure for removing the system fan, right-click System fan removal video and select Open link in new window/tab.
Replacement part information
The following HP part numbers are known to be compatible with this system:
Part Number
Requires Return
Chassis fan bracket
450710-001 (modified)
No
* If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. For more information about returning parts to HP select one of the links below:
System fan removal
Review the following safety considerations before performing the following steps. Failure to comply with these safety considerations could result in damage to the product.
Step 1
With all cables disconnected from the computer, remove the access panel.
Step 2
Disconnect the fan cable from the system board.
Step 3
Push on the tabs to release the top of the fan holder from the chassis.
Step 4
Rotate the fan holder away from the chassis wall.
Step 5
Lift the fan out of the chassis.
Step 6
Pull out on the tabs on the fan holder and lift the fan out of the holder.
System fan replacement
Step 1
Align the air flow arrows on the fan and the fan holder.
The fan must be installed in the correct orientation for proper air cooling.
Step 2
Press the fan into the fan holder until it snaps into place.
Step 3
Insert the bottom tabs on the fan holder into the slots on the chassis.
Step 4
Press the fan holder against the chassis until the top tabs snap into the chassis slots.
Step 5
Connect the fan cable to the system board.
Step 6
Replace the access panel.
