    Apache Log4j Update
HP Designjet Z6100 Printer Series - Cleaning the Encoder Strip
From Firmware version 9.0.0.4 onwards the printer will notify the user to clean the encoder strip when the printer detects that it is dirty. This new process must be initiated by the user, and the front panel will provide step-by-step instructions on how to clean the encoder strip.
  1. To start the procedure go to the Ink Menu and scroll down to select Clean Encoder Strip.
    Figure : Clean Encoder Strip option
  2. Once the process has started, the Front Panel will guide the customer on how to perform the cleaning procedure. Shown below are the screens from the Front Panel.
    Figure : Front Panel Screenshots
