HP Color LaserJet CM6030 and CM6040 MFP Series - Supported paper types
Tray 1 paper information
Type
Quantity
Driver settings
Paper orientation
Paper and cardstock, standard sizes
Range:
60 g/m2 bond to 220 g/m2 bond
Maximum stack height: 10 mm
Equivalent to 100 sheets of 75 g/m2 bond.
Plain or unspecified
Load preprinted or prepunched paper facing down, with the top edge leading into the tray, or toward the back of the product
Envelopes
Less than 60 g/m2 bond to 90 g/m2 bond
Up to 10 envelopes
Envelope
Short edge leading, flap toward the front of the product, facing up
Labels
Maximum 0.23 mm thick
Labels
Side to be printed on facing down
Transparencies
Minimum 0.13 mm thick
Transparencies
Heavy
0.13 mm thick
Light glossy, glossy, or heavy glossy
Glossy
Range:
75 g/m2 bond to 220 g/m2 bond
Photo media
Cut sheet paper
Tough paper
Trays 2, 3, 4, and 5 paper information
Type
Quantity
Settings
Paper orientation
Range:
500 sheets of 75 g/m2 bond.
Load preprinted or prepunched paper facing up, with the top toward the back of the tray or toward the right-hand side of the tray.
Labels
Maximum 0.13 mm thick
Maximum stack height: 54 mm
Labels
Side to be printed on facing up
Transparencies
Transparencies
Heavy
0.13 mm thick
Glossy
Photo media
Cut sheet paper
Tough paper
HP Tough Paper
To view an animation of removing trays right-click this link: Trays 2, 3, 4 and 5 (in English), and click Open in New Window.
Trays 2, 3, 4, and 5 capacity:54 mm height or 500 sheets of paper, whichever is less. Supported media types include: Cut sheet paper, labels, OHT, glossy paper, glossy film, photo media, and tough paper. Basis Weight: 60-220 g/m2.
Duplex printing: Provides automatic two-sided printing (printing on both sides of the paper). The paper size range for automatic duplex printing is 175 to 320 mm x 210 to 457 mm. The media weight range is 60 to 220 g/m2
HP Color Laser Presentation Paper, Glossy (Q2546A) is not supported with this product. Using this type of paper can cause a fuser jam that might require the replacement of the fuser. Two recommended alternatives are HP Color LaserJet Presentation Paper, Soft Gloss (Q6541A) and HP Color LaserJet Brochure Paper, Glossy (Q6611A, Q6610A).
For a complete list of specific HP-brand paper that this product supports, go to www.hp.com/sbso/product/supplies.
Country: Flag Thailand
