This information applies to the HP Pavilion w1707 monitor.
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion w1707 Monitor - Product Specifications
The HP Pavilion w1707 is a 17-inch wide-screen flat panel monitor with liquid crystal display (LCD) and
thin-film transistor (TFT) screen.
Figure : HP Pavilion w1707 LCD wide-screen flat panel monitor
KB744AA
Features
The HP Pavilion w1707 LCD wide-screen flat panel monitor has the following features:
- BrightView Technology enhances clarity and provides brilliant colors
- 1440 x 900 factory-set resolution
- Video inputs supported:
- VGA analog signal
- DVI-D digital signal
- Supports High-bandwidth Digital Content Protection (HDCP) to prevent transmission of non-encrypted high definition content
- Plug and play capability, if supported by your computer system
- On-screen display (OSD) adjustments for ease of setup and screen optimization
- Energy Star compliant
Technical specifications
LCD feature
Specification
Display size
17-inch (43.2 cm) diagonal and viewable image
Display type
Thin-Film Transistor LCD active matrix
BrightView technology
Input terminal
VGA 15-pin D-type connector
DVI-D connector (cable not included)
Speakers
2 integrated speakers
1 watt each, 2 watts total
Scanning frequency
Horizontal scan range 24-83 KHz
Vertical scan range 55-76 Hz
Native resolution (H x V)
1440 x 900
Contrast ratio
up to 600:1
Response time
8 ms (on-off)
Pixel pitch
0.255 mm
HDCP (High-bandwidth Digital Content Protection)
Support for HDCP enables the monitor to display HDTV resolution if connected by the DVI connector. A monitor without HDCP support, or connected by analog VGA, causes the displayed video to be downgraded in quality to a DVD-like resolution that is less than HDTV.
HDCP is also a content protection system. The goal of HDCP is to prevent transmission of non-encrypted high definition content.
Power source - AC/DC adapter
Input rating: 100 to 240V~
Power consumption: <37 W in operating mode, <2 W in sleep mode
Operating environment
Temperature: 41 degrees F to 95 degrees F (5 degrees C to 35 degrees C )
Humidity: 15% RH through 90% RH (non-condensing)
Storage environment
Temperature: -4 degrees F to 140 degrees F (-20 degrees C to 60 degrees C)
Humidity: 5% RH through 90% RH (non-condensing)
Dimensions
H x W x D, including base:
14.3 x 16.2 x 7.2 inches (36.4 x 41.4 x 18.4 cm)
Unpacked: 5.9 lbs (2.7 Kg)
EMI standard
FCC Class B
Mounting
Standard VESA 4-hole 100 mm x 100 mm
EPA Energy Star
As an Energy Star Partner, Hewlett-Packard has determined that this product meets the Energy Star guidelines for energy efficiency.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
