This motherboard has jumpers to clear the Real Time Clock (RTC) RAM in CMOS. In the default (normal) position the jumper is on pins 1-2.
To clear CMOS, follow these steps:
Temporarily set jumper JBAT1 to pins 2-3.
Wait 5-10 seconds and then return the jumper to pins 1-2.
On the next startup, enter BIOS setup to reset any custom BIOS settings.
