HP iPAQ 310 Travel Companion Series - Using a Contact as a Destination
Issue:
Setting a destination using a Contact's address.
Solution
Complete the following steps to set a destination using a Contact's address:
  1. Tap Go to.
  2. Tap Next > Contacts.
  3. Select Contact that you want to use as a destination.
  4. Tap the Green Checkmark icon.
    The Contact's address is shown by the Red cursor.
  5. Tap Set as Destination.
    The route will be configured.
