HP iPAQ 310 Travel Companion - Connecting to Paired Devices by Tapping the Connect Button under Bluetooth
Issue:
How to connect to a paired device from an HP iPAQ 310 Travel Companion.
Solution
Complete the following steps:
  1. First, the devices have to be paired via Bluetooth.
  2. Then, you have to create a shortcut for the device.
    After creating a shortcut, the Connect icon should be enabled.
A shortcut has to be created first, in order for the Connect icon to be enabled and used.
