HP LaserJet M1319f Multifunction Printer - Cleaning the HP Multifunction Printer
This document provides instructions to clean the product.
Cleaning the HP multifunction printer
Use the following procedures to clean the HP multifunction printer.
Cleaning the glass scanning strip and platen in the automatic document feeder (ADF)
  1. Use the power switch at the back of the product to turn off the product, and then unplug the power cord from the electrical socket.
  2. Tilt the control panel forward.
  3. Clean the glass strip and the white platen with a soft cloth or sponge that has been moistened with nonabrasive glass cleaner.
    Figure : Cleaning the glass and white platen
    Do not use abrasives like acetone, benzene, ammonia, ethyl alcohol, or carbon tetrachloride on any part of the product; these can damage the product. Do not place liquids directly on the glass or platen. They might seep into the product and damage it.
  4. Dry the glass and platen with a chamois or a cellulose sponge to prevent spotting.
  5. Plug in the product, and then use the power switch to turn on the product.
Cleaning the paper path
  1. Press the Setup button.
  2. Use the arrow buttons () to display Service menu, and then press the OK button.
  3. Use the arrow buttons () to display Cleaning mode, and then press the OK button.
  4. Load plain letter or A4 paper when prompted.
  5. Press the OK button again to confirm and begin the cleaning process.
    A page feeds through the product slowly. Discard the page when the process is completed.
Cleaning the exterior
Use a soft, damp, lint-free cloth to wipe dust, smudges, and stains off the exterior of the product.
