    Fix HP Printer issue on macOS
Blinking Lights on the HP Deskjet D2500 Printer Series
Blinking lights
The lights on the front of the HP product can be on, off, or blinking (flashing), depending on the status of the product. The lights indicate product status and are useful for diagnosing printing problems.
    Figure : Lights and buttons on the control panel
    Graphic: Lights on the product control panel
  1. Power light
  2. Cancel button
  3. Resume light
  4. Print Cartridge status lights
The following sections describe the most common combinations of blinking lights, followed by solutions for each combination. Find the blinking lights pattern you are experiencing, and then follow the steps to resolve the issue.
