HP Compaq dc5800 Business PC SFF Product Specifications
Product description
Packed with proven technology and enhanced features, the HP Compaq dc5800 Business PC is well equipped to meet the demands of mainstream organizations. Take advantage of the customizable productivity, manageability, and security features to achieve a unique PC that is designed to be the foundation of your business.A foundation that fits Rely on the latest technology from Intel to help deliver the performance and productivity your organization needs to fit a broad range of functions. Offering your choice of Intel processor technology, from Celeron to Quad-Core processors, and the Intel Q33 chipset, featuring Graphics Media Accelerator 3100 graphics with 3D enhancements, the HP Compaq dc5800 Desktop PC helps promote efficiency, deliver greater flexibility, and provide headroom for future technology expansion.
Product features
Features
Microtower
Small Form Factor
Intel Q33 Express chipset
Processor
Intel Core 2 Duo Processors, Intel Core 2 Quad Processors, Intel Pentium Dual-Core Processors , Intel Celeron D Processors
Memory
PC2-6400 (DDR2-800 MHz) Non-ECC DIMM Memory
Dual channel memory configurations supported for enhanced performance (requires both slots populated with same type and size memory).
Hard drive(s)
80-,160-, 250-, 500--GB SATA NCQ Smart IV 3.0GB/s hard drive (7200 rpm); 3.5” Removable 80-,160-, 250-GB SATA NCQ Smart IV 3.0GB/s hard drive (7200 rpm); 80-, 160-GB SATA NCQ Smart III 3.0-GB/s hard drive (10,000 rpm)
Expansion bays
2 internal 3.5" bays,2 external 5.25" bays, and 1 external 3.5" bay
1 internal 3.5" bay, 1 external 5.25" bays, and 1 external 3.5" bay
Full-height: 1 PCI ,2 PCIe x1, and 1 PCIe x16
Low-profile: 1 PCI ,2 PCIe x1, and 1 PCIe x16
Memory slots
4 DIMMs
Graphics
Integrated Intel Graphics Media Accelerator 3100
Audio
Integrated High Definition 4-channel audio
Communications
Integrated Intel Gigabit Ethernet NIC
I/O ports and connectors
Ten (10) USB 2.0 ports (two front, six rear, two internal USB header) one VGA port, DVI output (available via optional ADD2 card), one serial with second optional, two PS/2 ports (mouse and keyboard), front headphone and microphone jacks, RJ-45 port, parallel port optional
Input device
Standard keyboard and 2-button optical scroll mouse available as USB or PS/2, or USB 2-button laser mouse
Power
300-watt passive PFC Power Supply (user selectable 115V/230V); Optional 80% High Efficiency 300W Active PFC
240-watt active PFC Power Supply (user selectable 115V/230V); Optional 80% High Efficiency 240W Active PFC
Security
Integrated TPM 1.2 (standard); HP Desktop Security lock kit (lock and cable); Security cable with Kensington lock Protect Tools Software (optional)
Dimensions (h × w × d)
37.72 x 17.65 x 42.8 cm / 14.85 x 6.95 x 16.85 in
10.03 x 33.78 x 37.846 cm. /3.95" x 13.3" x 14.9"
23.44 lb (10.63 kg)
17.86 lb (8.10 kg)
Software/OS
Feature
Operating System
Preinstalled Genuine Windows Vista Business 32* Genuine Windows Vista Business 64* Genuine Windows Vista Home Basic32* Genuine Windows Vista Ultimate 32* Genuine Vista Business Edition with downgrade to Genuine XP Professional pre-installed. FreeDOS
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
