HP iPAQ 200 Enterprise Handheld Series - Setting up a Wireless Access Point (WAP)
Configure the HP iPAQ 200 Enterprise Handheld series to use a WAP gateway. This gateway connects wireless communication devices together to form a wireless network.
Configuring Wireless Access Point
Before configuring, obtain these information from your ISP, mobile phone service provider, or network administrator.
  • User name
  • Password
  • ISP server phone number
  • WAP gateway server name
  • Port number
Follow these steps to set up the connection.
  1. Tap Start > Settings > Connections tab > Connections > Advanced tab > Select Networks > My Work Network > Edit…. If a proxy server has not been set up, tap New…
  2. On the Proxy Settings tab, select the This network connects to the Internet and This network uses a proxy server to connect to the Internet check boxes.
  3. If necessary, in the Proxy server box, enter the proxy server name.
  4. Tap Advanced > WAP.
  5. In the Server box, enter the WAP gateway server name. Under Port, enter the port number.
    The most common WAP port number is 9201.
  6. Enter the logon credentials required by the WAP gateway server.
