    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
Printer Specifications for the HP Photosmart Pro B8850 Photo Printer
Figure : HP Photosmart Pro B8850 Printer
Product models
Printer model
Part number
Q7161A
Minimum System Requirements
Component
Windows
Macintosh
Microsoft® Windows XP and Windows Vista
Mac OS X v10.3.9, v10.4, and v10.5
Processor
A modern 1 GHz 32-bit (x86) or 64-bit (x64) processor or higher
PowerPC with G4, G5, or Intel® Core processor
Random access memory (RAM)
Windows XP and Vista Home: 512 MB
512 MB
Free disk space
400 MB (Windows XP) ; 800 MB (Windows Vista)
150 MB
CD-ROM drive
Required
Required
Browser
Microsoft Internet Explorer 5.01 with SP2 or later
Any browser
USB
USB port (Cable not included)
Connectivity
USB 2.0 High speed
USB 2.0 High speed
Physical dimensions
Dimension
Size
17.1 kg (37.7 lbs)
Height
235 mm (9.2 inches)
Width
675 mm (26.6 inches)
Depth
430 mm (16.9 inches)
Ink cartridges
Paper-handling specifications
Paper tray capacity
Tray
Capacity
Main tray
200 sheets of plain paper
60 sheets of photo paper
Specialty media tray
1 sheet of any media up to 0.7 mm thick
Output tray
50 sheets of plain paper
20 sheets of photo paper
Paper sizes
The product supports paper sizes 7.6 x 12.7 cm to 33 x 111.8 cm (3 x 5 inches to 13 x 44 inches), including:
Paper type
Paper size
Metric
10 x 15 cm (with or without tab), Panorama 10 x 30, 13 x 18 cm, A3, A4, A5, A6, B4, B5, E
Imperial
Index card 3 x 5 inches, Index card 4 x 6 inches, Index card 5 x 8 inches, 3.5 x 5 inches, 4 x 6 inches (with or without tab), Panorama 4 x 10 inches, Panorama 4 x 11 inches, Panorama 4 x 12 inches, 5 x 7 inches, 8 x 10 inches, 11 x 14 inches, 11 x 17 inches, 12 x 12 inches, 13 x 19 inches
U.S.
Letter, Legal, Executive, Tabloid
Japan
L, 2L, Hagaki, Ofuku Hagaki
Envelopes
Envelope No. 10, A2 envelope, C6 envelope, DL envelope Banner paper: Up to 13 x 44 inches
Banner paper
Media specification
Component
Size
Maximum length (main tray)
483 mm (19 inches)
Maximum length (specialty media tray)
1118 mm (44 inches)
Maximum width
330 mm (13 inches)
Maximum weight for main tray
220 gsm, non-rigid media
Maximum thickness for specialty media tray
0.7 mm, one sheet at a time
Printing specifications
Print speed
  • 28 ppm black text
  • 26 ppm mixed graphics
  • 90 sec 13 x19 draft
  • 10 sec 4x6 photo draft
Power specifications
Component
Specification
Printing
30 W (Average)
Sleep mode
Less than 6 W
Off
Less than 1 W (Average)
Environmental specifications
Recommended operating conditions
  • Recommended temperature: 15–35° C (59–95° F)
  • Recommended relative humidity: 20–80%
Maximum operating conditions
  • Maximum temperature: 5–40° C (41–104° F)
  • Maximum relative humidity: 5–95%
Storage conditions
The storage temperature-range for the product is -30–65° C (–22–149° F).
Energy star
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products.
ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information, go to www.energystar.gov.
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309. Plastic parts over 25 grams are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the product's life.
Regulatory specifications
FCC compliance
This equipment has been tested and found to comply with the limits for a Class B digital device, according to Part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses, and can radiate radio frequency energy. If it is not installed and used in accordance with the instructions, it might cause harmful interference to radio communications. However, there is no guarantee that interference does not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try correcting the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between equipment and receiver.
  • Connect equipment to an outlet on a circuit different from that to which the receiver is located.
  • Consult a dealer or an experienced radio/TV technician.
Any changes or modifications to the product that are not expressly approved by Hewlett-Packard could void the user's authority to operate this equipment.
