HP Neoware e90 Thin Client - Overview
Product description
The HP Neoware e90 is one of the most powerful thin clients available, offering impressive performance that is ideal for running local applications. With upgradeable flash and DDR2 memory, you will be surprised by all the power packed inside.
Product Features
Feature
Part Number DC -
CA21/G270 (V4)
Part Number BX -
CA9/G260
Processor
VIA Eden 800 MHz
CA21/G270 (V4)
  • CN700
CA9/G260
  • CLE266
System Memory
CA21/G270 (V4)
  • 1GB max memory
CA9/G260
  • 512MB max memory
Flash/RAM
  • Standard: 128MB Flash ROM/256MB DDR2 RAM
  • Maximum: 1GB Flash ROM/512MB DDR2 RAM
Video
Maximum video resolution and refresh rate:
Up to 1600x1200 @ 60 Hz or 1280x1024 @ 85 Hz, 32-Bit color depth
Up to 1600x1200 @ 85 Hz, 8-bit or 16-bit color depth
Audio
  • Ports: microphone in, speaker out – 1/8 inch (3.5 mm) jacks / Internal speaker
Networking
  • Autosensing, 10/100 Ethernet, RJ-45, WakeOnLAN, PXE boot
  • Internal or external (USB) wireless options (a/b/g)
I/O
  • Serial connectors – two D-Sub 9-Pin/ Parallel connector – one D-Sub 25-Pin
  • USB 2.0 connectors –four (two front, two back) PS/2 connectors – one keyboard, one mouse
Peripheral support
  • Local printer support in ICA, RDP, and local applications 2
  • USB drive support (including flash drives) 2
  • USB Smart Card support 2
  • USB biometrics device support 2
  • Touch screen support
1 Wireless access point and Internet service required and not included. 2 May require additional device drivers from manufacturer.
Physical specifications
Dimensions: 1.6" W x 9.3" H x 8.7" D (4.2 cm x 23.9 cm x 22.2 cm)
Weight: (with keyboard): 8.5 lbs (3.9 kgs)
Environmental
Operating temperature: 32-95° F (0-35° C)
Operating humidity: 20-80% non-condensing
Power requirements
100-240 VAC, 50-60 Hz 25 W typically
Certifications
FCC, CE, VCCI, TUV GS, C-TICK, cUL, GOST, SABS, S-MARK, CCC, WEEE, RoHS
Limited three-year hardware warranty
Software Overview
Feature
Operating systems available:
  • NeoLinux
  • Genuine Windows® CE
  • Genuine Windows® XP Embedded
Server OS Compatibility/ Support
  • Citrix Presentation Server 4.0 including the Desktop Broker feature
    Requires minimum ICA client version 9.x
  • Citrix Presentation Server 4.5 including the Desktop Broker feature
    Requires minimum ICA client version 10.x
  • Citrix Metaframe Presentation Server 3.0
  • Citrix Metaframe XP Presentation Server
  • Citrix Metaframe 1.x · Windows 2000/2003 Server Terminal Services
  • Windows 2000 Advance Server Terminal Services
  • Windows NT 4.0 Terminal Server Edition
  • VMware Virtual Desktop Infrastructure using RDP
  • Linux Terminal Server Project (LTSP)* Most mainframes and midrange servers**
    *Requires BIOS change to PXE boot ** Requires TeemTalk (standard on most HP Neoware thin clients)
Links to Product Specification and Warranty Information
Information for this Overview is taken from the product QuickSpecs. To access the complete QuickSpecs for this product, select the desired link from the following list:
