    Fix Windows 10 Update Issues
HP Notebook PCs - How to Clean the HP Webcam Lens
Fixing a blurry HP webcam image
If the HP webcam image is blurry, it is advisable to clean the webcam lens with a soft cloth.
Cleaning the HP Webcam
To clean the HP webcam, use a soft, non-abrasive cloth, such as a microfiber screen dusting cloth. You can find a suitable screen-dusting cloth at a computer store. Gently rub the webcam lens with the cloth.
