    Fix HP Printer issue on macOS
HP iPAQ 300 Travel Companion Series - GPS Shows Wrong Directions
Issue:
The GPS is showing wrong directions.
Solution
You may have entered the wrong street name.
Check the street name for the following:
  1. Make sure the spelling of the name selected or entered is correct.
  2. If the street name is common, a list of all such names display on the Travel Companion. Make sure to select the exact street name.
It is easy to select a different name, if you are in a rush or do not read the list properly.
