    Looking for Site Help?
HP LaserJet M2727 MFP Series Product - Configure the network product
View settings
Network configuration page
The network configuration page lists the current settings and properties of the product network card. To print the network configuration page from the product, complete the following steps.
  1. On the control panel, press Setup.
  2. Use the arrow buttons to select Reports, and then press OK.
  3. Use the arrow buttons to select Network report, and then press OK.
Configuration page
The configuration page lists the current settings and properties of the product. You can print a configuration page from the product or HP ToolboxFX. To print the configuration page from the product, complete the following steps.
  3. Use the arrow buttons to select Config report, and then press OK.
A second page also prints. On that page, the Fax Settings and Imaging Settings sections provide details about the product fax settings.
Change settings
You can use the embedded Web server (EWS) or HP ToolboxFX to view or change the IP configuration settings. To gain access to the embedded Web server, type the product IP address in the address line of a Web browser.
You can view HP ToolboxFX when the product is directly connected to a computer or when it is connected to the network. You must perform a complete software installation to use HP ToolboxFX.
Open HP ToolboxFX in one of these ways:
  • In the Windows system tray, double-click the HP ToolboxFX icon.
  • On the Windows Start menu, click Programs (or All Programs in Windows XP), click HP, click the product name, and then click HP ToolboxFX.
In HP ToolboxFX, click the Network Settings tab.
From the Networking tab (EWS) or the Network Settings tab (HP ToolboxFX), you can change the following configurations:
  • Host Name
  • Manual IP Address
  • Manual Subnet Mask
  • Manual Default Gateway
Changing the network configuration might require you to change the browser URL before you can communicate with the product again. The product will be unavailable for a few seconds while the network resets.
IP address
The product IP address can be set manually, or it can be configured automatically via DHCP, BootP, or AutoIP.
Manual configuration
  2. Use the arrow buttons to select Network config, and then press OK.
  3. Use the arrow buttons to select TCP/IP config, and then press OK.
  4. Use the arrow buttons to select Manual, and then press OK.
  5. Use the alphanumeric buttons to type the IP address, and then press OK.
  6. If the IP address is incorrect, use the arrow buttons to select No, and then press OK. Repeat step 5 with the correct IP address, and then repeat step 5 for the subnet mask and default gateway settings.
Automatic configuration
  4. Use the arrow buttons to select Automatic, and then press OK.
    It may take several minutes before the automatic IP address is ready for use.
If you want to disable or enable specific automatic IP modes (such as BOOTP, DHCP, or AutoIP), these settings can be changed by using the embedded Web server or HP ToolboxFX only.
IPv4 and IPv6 settings
Only the IPv4 protocol can be configured manually. The IPv4 protocol can be set from HP ToolboxFX or from the product control panel. The IPv6 protocol can be selected only from the product control panel.
Link speed setting
Incorrect changes to the link speed setting might prevent the product from communicating with other network devices. For most situations, the product should be left in automatic mode. Changes can cause the product to power cycle. Changes should be made only while the product is idle.
  3. Use the arrow buttons to select Link speed, and then press OK.
  4. Use the arrow buttons to select one of the following settings.
    • Automatic
    • 10T Full
    • 10T Half
    • 100TX Full
    • 100TX Half
    The setting must match with the network product to which you are connecting (a network hub, switch, gateway, router, or computer).
  5. Press OK. The product will power cycle.
Country: Flag Thailand
