HP Designjet T1100 and T1120 MFP Series Products - Create a Custom Scale Size
Create a custom scale size
You can set a custom scale size value from the Copy tab and from the Scan tab.
  1. Press the Copy tab or Scale button if you are performing a copy job or. Press Scan tab, Resize if you are performing a scan to file job.
  2. Press the Scale button and then the Tool button
  3. In the Scale Setup dialog, press the New button. Scale setup dialog
  4. Enter a name for your new scale. Using the scale value itself as the name is recommended (i.e., "72%")..
  5. Press the Value button and set the scale value.
  6. Press the Save button and then OK to confirm..
Your new scale will join the standard scales in the scale presets list.
