    We are upgrading our website
Document ID: c01177960
Version: 1
HP xw6400 and xw8400 Workstation - Workstation may reboot with "930 - Non-fatal Error"
Release date : 27-Sep-2007
Last updated : 27-Sep-2007
DESCRIPTION
The workstation may reboot to the F1 prompt when the following error occurs:
“930 – Non-fatal internal Northbridge error” with sub error “B6err: Single ECC error”
sourceInformation
SCOPE
  • HP xw6400 and xw8400 Workstation.
  • System BIOS v 2.24 or earlier.
RESOLUTION
Update the system BIOS to v 2.25 or later:
  1. Select your workstation model.
  2. Select “Download drivers and software.”
  3. Select your operating system.
  4. Select “BIOS”
  5. Download the BIOS package (v 2.25 or greater) and carefully read the instructions before proceeding.
RECEIVE PROACTIVE UPDATES: Receive support alerts (such as the document you are reading), as well as updates on drivers, software, firmware, and customer replaceable components, pro-actively via e-mail through HP Subscriber's Choice for your specific HP Workstation. Click here to sign up for Subscriber's Choice
Hardware platforms affected : HP xw6400 Workstation, HP xw8400 Workstation
Support Communication Cross Reference ID : IA01177960
Country: Flag Thailand
